Alternator bracket kit - Page 2
Old January 24th, 2012, 03:24 PM   #21
ryanw's Avatar
1991 Ford Mustang GT
Originally Posted by e3sean View Post
that is where the lower radiator hose goes.
All right....now i feel dumb, lol,
Originally Posted by fogged306 View Post
That's the inlet for the pump. It's just the blue part. Not sure what black part you're talking about, but if it's what I'm thinking you're referring to, that's the tie-rod boot on the rack. They do kind of line up at the angle I took the pic.
Ya from the angel it looks like one piece.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 24th, 2012, 03:27 PM   #22
e3sean's Avatar
1988 lx
9.68@142
back in the fuel injectd days
<font size=4><b>MILITARY CREW
Old January 24th, 2012, 03:28 PM   #23
fogged306's Avatar
89 GT
what is wit the blue waterpump though... paint the waterpump black and the msd cap black and it will look way better
Yea I agree. I probably will when I get some time to yank the pump off.
Old January 24th, 2012, 03:30 PM   #24
fogged306's Avatar
89 GT
Holy fuck, that vac pump doesn't like RPM huh? lol.
Old January 24th, 2012, 03:35 PM   #25
e3sean's Avatar
1988 lx
9.68@142
no the origional plan was 8000 rpm shifts. the vac pump isnt supposed to spin higher then like 7 or something like that. it pulls some air though even with the steering wheel pully.
Old January 24th, 2012, 03:35 PM   #26
ryanw's Avatar
The second pic vs. The first..... did you get a low mount alternator bracket, in order to delete the two idler pulleys ?
Thats a really big idler pulley in the first pic, never really seen them that big.
Love the engine bay, nice work, how many hours you got into it ?
255 fuel pump,
3:27 gears
Old January 24th, 2012, 03:40 PM   #27
ryanw's Avatar
E3sean.....i could have swarn you had a carb, on the last video i saw of your car, am i wrong or have you upgraded to fuel injected, either way, i like the fact that its efi..
255 fuel pump,
3:27 gears
Old January 24th, 2012, 03:43 PM   #28
e3sean's Avatar
1988 lx
9.68@142
read the line above the pic..lol (back in the fuel injected days)
i made that bracket for the ideler pully. i used a combanitation of my alternator bracket and a smog pump delete kit pully.its the same alt bracket i both pics.
i chucked up the pully on the lathe and shaved the ribs off and then drilled a hole in the alt bracket and spaced it out the way i wanted.
Threads Similar to: Alternator bracket kit
Is This An Alternator Bracket And Where Does It Go? Gregski Mustang II 8 December 21st, 2010 10:33 PM
94-95 Alternator Bracket 95stroker 94-95 9 October 28th, 2010 11:58 AM
alternator bracket!!!! show95stang 5.0 Mustangs 4 June 1st, 2008 01:51 PM
alternator bracket 91cobra5.0 5.0 Mustangs 0 May 29th, 2008 06:55 PM
