1991 Mustang LX 5.0
Alternator bracket kit
Been looking around a little bit in Summit and Jegs for an alternator mounting kit as I am going to only have the crank, water pump, and alternator left in the engine bay. Who has used what kit, where did you get it, and pics if you have them of it mounted up. Any help is appreciated!
Scott
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Canary yellow 1990 GT
Praying for 11's after winter mods
I ordered some stuff from summit on Friday and got the march kit... my engine should look like this... minus all the bling of course.
-Edelbrock Performer Intake/Heads -TFS2 Cam -Tremec 3550 -All them other bolt on performance thingys |
1991 Ford Mustang GT
Are you looking for a high mount, mid mount or ,low mount ?
1991 Mustang LX 5.0
Mid or low. So far, I like Aaron Price's the best, but to run it with the water pump, it looks like I'd have to run a standard rotation water pump (from like a crown vic) and then I'd have to change the pulley to a ribbed one (that ASP makes), but I like it the best so far. Hopefully I get some more responses, and maybe I'll find something easier. Otherwise as far as looks go, I like it.
What is your price range ?
1991 Mustang LX 5.0
It's not so much the money as it is how it looks and where it places the alternator. I have an issue with things being symetric. So if it's mid mount, it won't look like something really out of place, if that makes sense. Plus I want keep all the working room that I can, and if it's up high, then it's just in the way of running a cooler looking upper radiator hose. Just weird like that, lol. Did you google the one that I was posting about?
No....i ebayed sbf aternator brackets, and the price goes from 30-178 bucks
Give me a link to what your looking at, that will give me a good idea to watch for
1991 Mustang LX 5.0
Ya i agree scott, i like those kits he has, and the price seems fine. I just hate to change water pumps, but thats just me.
89 GT
I've got Aarons kit on my car and it was definitely money well spent. Well made kit.
1991 Mustang LX 5.0
Just ordered Aarons kit. Best option I've found! My WP looks crappy anyway, lol.
I read every post, and out of 7 pages there was only one guy at the end, that said his bracket moved a little when ever he checked his belts.....
1988 lx
9.68@142
switch to an electric waterpump then just run crank/ alternator. then you can drop it low and use a small belt. looks way better.
89 GT
You mean like this?
1991 Mustang LX 5.0
I will when I do the 351. Just not with this 302... I ordered, the bracket, the ribbed pulley from ASP, and just have to get the water pump yet which I will do with my buddies shop discount. When I go 351, I will just buy another kit from Aaron, and sell this setup including pulley and water pump off as a kit to someone else that can use it.
What is the blue rod with the black tip sticking out if the electric water pump on the drivers side ?
1988 lx
9.68@142
that is where the lower radiator hose goes.
89 GT
That's the inlet for the pump. It's just the blue part. Not sure what black part you're talking about, but if it's what I'm thinking you're referring to, that's the tie-rod boot on the rack. They do kind of line up at the angle I took the pic.
1988 lx
9.68@142
what is wit the blue waterpump though... paint the waterpump black and the msd cap black and it will look way better
1988 lx
9.68@142
mine is set up similar except i have a vacuume pump as well
Threads Similar to: Alternator bracket kit
| Is This An Alternator Bracket And Where Does It Go? | Gregski | Mustang II | 8 | December 21st, 2010 10:33 PM |
| 94-95 Alternator Bracket | 95stroker | 94-95 | 9 | October 28th, 2010 11:58 AM |
| alternator bracket!!!! | show95stang | 5.0 Mustangs | 4 | June 1st, 2008 01:51 PM |
| alternator bracket | 91cobra5.0 | 5.0 Mustangs | 0 | May 29th, 2008 06:55 PM |
