1990 Mustang GT
My car started running like shit today
I just got home from work. On the way home I notice that If I get on it the motor wont rev past 3000rpm without stumbling. It's like it hit a rev limiter. While sitting at a red light i put it in neutrel and tried to rev it and it backfired out of the tail pipes. The only thing I checked since I got homs was the throttle. It isn't sticking-I'm getting wot. Could this possibly be a fuel issue? Fuel pump?
1990 Mustang GT
By the way it's running great at part throttle.
1991 Ford Mustang GT
First thing id check is fuel pressure, if that checks out, id try running your codes, and see what pops up.
1988 lx
9.68@142
Fuel pressure. If thats good do a tps voltage check. Usually it's the fuel pump starting to go out.
1991 mustang 5.0
Yeah I would say fuel pumP as well.
1990 Mustang GT
It's running great now.I remember when I first bought the car,the previous owner told me not to use BP gas.The last two times I got gas before it started running like crap, I bought premium gas from Bp mostly out of convienence .I was running low so I filled up with Marathon premium and it runs perfect now. Is it the bp gas,maybe rust in the tank,fuel pump sock or the pump? I've heard the Bp thing before but I figured it was a myth.I figured gas was gas. I'm runng 13degrees of timing.
Id still check the fuel pressure, it only takes a min if you have the gauge
Threads Similar to: My car started running like shit today
| Help. Car is running like shit. | energiesource | 99-04 | 21 | September 16th, 2009 09:08 PM |
| my car is running like shit | B0B | 99-04 | 80 | March 15th, 2009 04:14 PM |
| haven't started the barely-running coupe in 7 months | USMCam | Classic Mustangs | 11 | September 1st, 2008 11:43 PM |
| Car started running like crap! | Euroeater95 | 94-95 | 3 | April 11th, 2008 10:51 PM |
