foxbody dash help!! Electrical!
howdy folks I'm having some issues with my fox and was hoping someone might have some ideas. So the dash board illumination lights don't work, neither does the a/c nobs and window switch's illuminate. so the car was origonally a 1991 4 cylnder and now its a carbeurated 351 windsor. all the other electronic systems work that I can think off except all of the button/dash illuminations. even the door switch doesn't light up but the switch does operate. I checked all the fuse's, their all fine. I herd if you have a 4 cyl computer this will happen with a v8? the only thing is that the computer is not hooked up, the computer harness was cut at the fire wall. I'm starting to think maybe thats a possible reason? ANY help is always appreciated.
1991 Mustang LX 5.0
Dash dimmer is shot, most likely. Nothing to do with the engine harness. Common issue with the fox's. Mine had to be on its 'sweet spot' to illuminate the lights. Low and behold, it was trying to burn the car down.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
meh
The engine harness is entirely separate from everything else. The engine harness runs through the passenger side firewall, and everything else goes through the drivers side firewall. The 5.0 LX and 4 banger dash harnesses were the same, so that doesn't matter. (GTs had an extra set of wires for the additional idiot lights to the right of the steering wheel, low fuel, low coolant, etc.)
For illumination issues, I'd start with the dimmer switch and go from there, just like FastStang91Lx said. All of the illumination stuff runs through that switch. If there is a dead spot in the switch, none of the interior nighttime illumination lights (at least the ones that can be dimmed) will work. You can try messing with the switch (i.e. roll the wheel back and forth a few times) to rub off any dust that may have accumulated on the switch element, but if it has completely burned out, that won't do any good.
'87 2.3 Notch with +4 cylinder mod ![]() Ass, Cash, or Grass.. nobody rides for free Black Stang Crew Member #11 |
1991 Ford Mustang GT
Latemodelresto.com
1987-93 Mustang Instrument Panel Dimmer Switch by Ford at LRS - Same Day Shipping! Foxresto.com Fox Mustang Restoration :: Products
2001 Ford Mustang Cobra
I've got a dimmer switch I can sell you for like $25obo shipped.
2001 Ford Mustang Cobra---1993 Notch Colorado Car Forum Bringing Horsepower Junkies together!! |
Thank you All for the help! that issue has been such a burden for me for so long! I'll deffinetly be checking that out!
If it is the dimmer switch, would that cause the window switch buttons not to illuminate as well? i'm guessing/hoping their on the same circuit??
meh
Now that I think about it, Fox window switches and door lock switches do not have lights in them. They just have white paint for the "up" and "down" "lock" and "unlock" etc.
#10 | |
To the OP they dont light up...lol
Foxbody5.0
1987 Mustang GT
Foxresto.com your one stop shop for everything Fox. I love that site.
Threads Similar to: foxbody dash help!! Electrical!
| Need Electrical Guru's help! Electrical gremlins in my cluster | 94FiveOVurt | 5.0 Mustangs | 6 | August 8th, 2011 07:37 PM |
| Foxbody C4? | stangage | 5.0 Mustangs | 4 | August 13th, 2009 08:47 AM |
| A/c on 93 foxbody | sctravis77 | 5.0 Mustangs | 2 | March 6th, 2009 07:39 PM |
