1993 Mustang GT
Timing issue
I accidentally tried to time my car with the gray chip installed that shows the computer the timing,it's located on a plugin right by the distributor,do you know what I'm talking about?i was just wondering of this did any harm to my motor,do I just need to take the chip out and retime it and everything will be okay?
Sent from my Autoguide iPhone app Sent from my Autoguide iPhone app
1993 Mustang GT (Reef Blue on platinum) 105k Miles, still strong. BBK CAI Dual Flowmasters Hurst Shortshifter Smog Delete Gatorback pulleys. FULL LED Tailights NEWEST ADDITION: Eaton M90 supercharger kit |
1991 Ford Mustang GT
Just pull the spout connector out and retime it, and youll be fine
1991 Mustang LX 5.0
No harm done. You actually just retarded it from where it should be.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1993 Mustang GT
Okay thanks a lot guys.i accidentally moved it when replacing my t stat and housing.looks like I'll need to pick up a timing wrench too.
1991 Mustang LX 5.0
You don't need a timing wrench. Hell, you can do it with a regular wrench or a ratchet, extension, and swivel.
1993 Mustang GT
I haven't been able to find anything that works!whats the highest you guys set your timing at 14?
1991 Mustang LX 5.0
14 normally. Are you sure your balancer hasn't spun on the rubber at all?
1993 Mustang GT
I got it fixed today
haha thanks guysSent from my Autoguide iPhone app
1991 mustang 5.0
I got mine at 15 degrees. Could probably go higher.
1993 Mustang GT
Nice mine idles right below 1000 but sometimes it stays at 1200 and won't go down...should I be worried?no signs of pinging at all.
1991 mustang 5.0
Mine idles at 650
89 GT
Factory target idle is 672 RPM. Stock tachs are off so you can't really go by them, but if you have an aftermarket tach and are idling at above 1k, you've got an issue. Could be something as simple as needing the base idle reset, or could be a vac leak, or too much timing.
1993 Mustang GT
I don't have an aftermarket,but whenever I time it,it adjusts the idle too...pinging is the only real thing to be worried about right?ill keep you guys posted in case I need to troubleshoot
14* for stock heads 18* with tf tw heads
1993 Mustang GT
That high idle worries me but I'm holding to the fact that there's no pinging and that the stock tach isn't accurate..
89 GT
Advancing the timing will increase your idle. If you've got no pinging, you're not doing any harm. Try resetting your base idle and see how that goes. If you don't know how, there's a sticky at the top of this forum with a link to the procedure.
1993 Mustang GT
Thanks
Threads Similar to: Timing issue
| timing issue again | 6ixer | V6 Mustangs | 4 | November 12th, 2011 01:01 PM |
| Timing issue | Stangalang81 | 2005 - 2010 | 14 | September 14th, 2011 01:35 PM |
| I NEED HELP!Timing issue | PhillyGT | 5.0 Mustangs | 14 | May 9th, 2010 12:02 PM |
| Timing Issue | fugie | 99-04 | 4 | January 11th, 2010 04:18 PM |
| Timing issue. Help. | tehdwarvenn | 5.0 Mustangs | 4 | October 12th, 2008 10:30 PM |
