welding up the engine bay - Page 6
Old February 4th, 2012, 12:04 PM   #101
skeletonpsycho's Avatar
1987 mustang GT
10.92@122
skeletonpsycho is on a distinguished road
cool bro ill have to post some in there then
http://www.youtube.com/watch?v=gQ7g9ystpiU 347 all motor wawa pump gas driven everywhere
Old February 4th, 2012, 07:12 PM   #102
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
I love seeing clean engine bays like these, it'll make it worth the work
Old February 12th, 2012, 08:24 PM   #103
ryans88gt's Avatar
In the process of doing mine. As Sean said, scott rod panels. Shock towers, inner fenders, HVAC cover, frame rails. All together cost about $200 and only wieghed about 10-15 lbs all together. Gunna paint soon
Old February 12th, 2012, 08:27 PM   #104
ryans88gt's Avatar
Glad I bought them and didn't spend the time to make them. This was a huge project without having to fab the panels
Old February 12th, 2012, 08:30 PM   #105
ryanw's Avatar
1991 Ford Mustang GT
Oh wow, nice to see you back ryan,
Good name by the way, hope you stick around, your projects are all ways fun to follow
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 12th, 2012, 08:46 PM   #106
fogged306's Avatar
89 GT
You get that engine in the car you were putting together for that?
Old February 12th, 2012, 08:53 PM   #107
ryans88gt's Avatar
Well, as you can tell, nothing is in the engine bay right now...
but here...
Old February 12th, 2012, 09:04 PM   #108
fogged306's Avatar
89 GT
Nice.. Those CHI's ported or do they flow 359 out of the box? How much were those pistons by the way? I really want to go the cleveland route for my next top end but it's so damn expensive.
Old February 12th, 2012, 09:40 PM   #109
ryans88gt's Avatar
before and after port numbers are on the sheet. They flowed 349 cfm essentially out of the box... I just did a little port matching.
They flowed 359 after a little more cleanup and a comp valve job. think with a full serious port job they could get up into the 370-380 range, the cross section area is the same as cast.
The pistons weren't cheap, they were custom deals due to the 4.125 bore.
$1000 i think. Woody at fordstrokers put the short together... I think it was somewhere in the $5000 range. Pricey, yes. Good to 1000 hp... also yes.
Old February 12th, 2012, 09:45 PM   #110
ryanw's Avatar
Which car is this going in, cuz last time you were on here i believe you had just bought a supercharged 94-95 stang, wasnt sure if its going into that or not
255 fuel pump,
3:27 gears
Old February 12th, 2012, 09:50 PM   #111
ryans88gt's Avatar
In my 88 that I've had since '98.
This one
Old February 12th, 2012, 09:53 PM   #112
brandon444's Avatar
91 Mustang LX 5.0
its been a while since ive updated you guys, you aint kidding bout it being alot of work, luckily i need a good project like this tho
passenger side
driver side
firewall
radiator support
its coming along pretty good, almost ready to paint the whole bay just small tough up spots to fix yet
Old February 12th, 2012, 09:58 PM   #113
nkausch's Avatar
94 Mustang Gt
nkausch will become famous soon enough
That looks great. Can't wait to see it paintsd
94 Mustang Gt Vert-Mods: Tubular Headers, BBK Catted X, SLP Loudmouth 2's, EGR Delete
Old February 12th, 2012, 10:00 PM   #114
ryanw's Avatar
This one
561 hp Fox on the dyno at redline - YouTube
That SWEET....
255 fuel pump,
3:27 gears
Old February 14th, 2012, 01:05 AM   #115
brandon444's Avatar
91 Mustang LX 5.0
DONE!!!
well almost lol, ive got the first coat on it
it might look like primer to some of you guys but its a really close match to the actual color of my car
heres a whole shot of the car
Old February 14th, 2012, 01:54 AM   #116
ryanw's Avatar
What is your plan for the windshield wiper fluid box, and fresh air for the air filter?
255 fuel pump,
3:27 gears
Old February 14th, 2012, 02:20 AM   #117
brandon444's Avatar
91 Mustang LX 5.0
no wiper fluid and for the intake im doing what sean did
Old February 14th, 2012, 08:30 AM   #118
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Originally Posted by brandon444 View Post
DONE!!!
Coming together nicely. Might be alot of work but the finished product will be well worth it in the end.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old February 14th, 2012, 10:43 AM   #119
ryanw's Avatar
Dont forget to prime and paint the out side of the panels.....even if you cant see it, you dont want it to rust though after a couple of years
255 fuel pump,
3:27 gears
Old February 14th, 2012, 11:43 AM   #120
brandon444's Avatar
91 Mustang LX 5.0
already did the back sides. there was a few spots of surface rust but I cleaned it off and painted it
Threads Similar to: welding up the engine bay
Welding spike spiegel The Clubhouse 14 December 23rd, 2008 11:17 PM
This guy needs a little welding help. 06VistaBlueGT Videos 18 October 25th, 2008 05:06 PM
welding terribleonexx88 5.0 Mustangs 0 September 9th, 2007 06:17 PM
welding terribleonexx88 Northeast 0 September 9th, 2007 06:15 PM
Welding Horseshoeing The Clubhouse 10 May 21st, 2007 06:08 AM
