A/C issue
Old January 25th, 2012, 07:51 PM   #1
2vPOWA is on a distinguished road
A/C issue
Alright so a few weeks after I got my car my a/c went out. Turns out the actual compressor is fine and spins freely. I was looking online and found and artivle saying that I can either replace the a/c ($120 )itself or I can replace the A/C clutch hub ($40) which is this
Amazon.com: Motorcraft YB289A New Air Conditioning Clutch Hub: Automotive Amazon.com: Motorcraft YB289A New Air Conditioning Clutch Hub: Automotive
Does anyone have any input on this? I want to do my a/c before it starts getting warm out here in the desert.
93 LX Hatchback H/C/I Full Suspension
06 Ford Explorer Limited
Old January 25th, 2012, 07:57 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
Whats is it doing that makes you think that its the part thats bad, are you sure your not just low on freon ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 25th, 2012, 09:04 PM   #3
Freon is fine. The rubber broke in the front of the a/c compressor. The clutch itself actually tries to engage but that rubber seal is busted.
Threads Similar to: A/C issue
Intake manifold issue or head issue? sledgehammer357 All Other Vehicles 2 July 20th, 2011 01:58 AM
tcs issue or something else? zinsavage123 99-04 4 March 7th, 2011 01:47 AM
mafia issue? maf issue?? help nateCR 99-04 2 September 22nd, 2010 09:00 PM
um c my 4d we have an issue joejoe8455 The Clubhouse 15 April 29th, 2009 03:48 PM
