1989 GT 'vert
Roller rocker preferences???
Hey all, I just wanted some opinions, and brands of what kind of roller rockers you guys are running on your heads, particularly TFS 170's. What are some good recommended brands? I'm looking at Scorpions right now on Summit. anyone have any experiences with those? Thanks in advance!
1991 Ford Mustang GT
I have
crane energisers roller rockers
Mustang Fanatic
1989 Mustang LX
I have Scorpion Rockers.
good stuff.
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
1989 GT 'vert
Are you running them on twisted wedge heads?
Mustang Fanatic
1989 Mustang LX
AFR 185s
1989 GT 'vert
Guess I probably coulda caught that from your mods description LOL
1989 Black LX---Turbo
I'm running Harland Sharp on my TW 170's, My son is running Scorpion on his TEA TW 185's, and my other son is running Scorpion on his AFR 165's, I'm also running Comp Pro Magnum's on my RHS 180's, and Comp Pro Magnum's on my new Fox Lake ported TW 170's, all excellent rockers. I've also run Ford Racing, Crane Gold(a little noisy), Trick Flow & Crane Energizer in the past with no problems!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1989 GT 'vert
Damn! Sounds like you've run the full spectrum of rockers! Thanks! I'm thinking I'm gonna go with the scorpions. The issue I'm having is while I'm measuring for push rod length, every push rod I've tried, including the measuring tool is rubbing in the top of the push rod channel of the cylinder head. I called trick flow, and their first recommendation was to get rid of the pro form rockers I have. Have you ever had that problem?
#9 | |
1989 GT 'vert
Ok, cool. I'd planned on using the stock valve covers for now. Any recommendations on rockers that don't have clearance issues?
Threads Similar to: Roller rocker preferences???
| Roller rocker, pushrod? | rauscher89lx | 5.0 Mustangs | 5 | September 29th, 2011 08:40 AM |
| roller rocker ?' | Sally845 | 5.0 Mustangs | 8 | January 17th, 2011 07:41 PM |
| Roller Rocker Arm Kit | scxc15 | V6 Mustangs | 24 | January 25th, 2008 08:09 AM |
| Roller Rocker help | sniperrider | 5.0 Mustangs | 12 | August 31st, 2007 10:00 PM |
| roller rocker ? | marcd | 5.0 Mustangs | 15 | June 25th, 2007 10:35 PM |
