1992 Lx hatch
wheel and tire combo?
about ready to choose wheels and tires.. i want 17x9 in front and 17x10 in rear any suggestions on tire size?
also i have ebiach drag springs which lower it right? |
Mustang Fanatic
1989 Mustang LX
245/45r17 front
275/40r17 rear
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
1991 Mustang LX 5.0
+1
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Same combination I have but...
I don't know my specific rims backspacing but I would research some specific dimensions first. I have 17x9 with a 245 on the front and the tires rub the struts and the rim hits the a arms at 3/4 lock on both of my foxes (one lowered and one not) and I had to roll my fenders to get the 275 to not rub in the back which a lot of people have to do but my point is if I had a different backspacing to make the front work, that same spacing would make the rears rub even worse. I'll never do a 9 inch in the front again, anything less than a 245 doesn't look right on the rim and is too small and besides the rubbing, it seems to track and catch every slight imperfection in the road.
#5 | |
1991 Ford Mustang GT
A 225/45 looks good on a 15x8. I have no idea how that looks on a fox though, probably a little to small, it looks good on a Miata
. Maybe a 225/50 instead?I had a 235/45 on a 17x9 and thought it was too small, actually that is it on the front of the red car in my sig. Just my opinion though as I'd rather have 16 in rims.
Mustang Fanatic
1989 Mustang LX
On a 15x8 inch wheel, a 225/55 or 225/60 will look about flush with the rim..
My cousin uses 225/45 on his 17x8 '98 cobras.
Oh okay, i just dont want the wheel to be wider then the tire....you know how the low riders cars are ...lol, its going to be a while before i get new wheels, but i was debating on 15x 8 in the rear and 15x7 in the front, id like to just order the same size wheel all the way around but if a 225 wide tire is goin to look dumb on a 8 inch wheel then ill step down to 7 inch, but only on the fronts, id like to see pics if any one has any on both combos.
Mustang Fanatic
1989 Mustang LX
What style wheel?
Weld rodlites,
Mustang Fanatic
1989 Mustang LX
If you're gonna go with a 15x8, Id run a 245 up front. I'm guessing you're going with a Drag Radial for the rear right?
I dont know if i really want to go that big of a tire on the fronts, maybe i just need to go with the 15x7 up front
Mustang Fanatic
1989 Mustang LX
MM&FF put a 265/35/18 in the front of a 93 cobra.
And had no issues. 245 is also what I run in the front, no issues. If you really wanna get all 15x8, thats what I would do. I'm actually gonna get some race stars 17x4.5 front, and 15x8 rear cobra brakes lol. They look nice as hell tho
1990 ford mustang GT
just so u know there's 2 types of eibach springs for the mustangs, the lowering springs and the drag springs. the drag springs does not lower the car at all.
I.D.G.A.F.
Fox bodies should only be allowed to run big and littles in my opinion...
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
Threads Similar to: wheel and tire combo?
| Wheel/Tire Combo | clodingos97 | 99-04 | 6 | February 17th, 2011 05:05 PM |
| best tire/wheel combo for 99 v6 | thomasdale2144 | V6 Mustangs | 11 | January 14th, 2011 02:20 AM |
| Tire Wheel Combo | JOHNNY K. | 99-04 | 6 | April 10th, 2008 11:20 AM |
| Wheel and tire combo??? | flamed 98 gt | 5.0 Mustangs | 0 | March 5th, 2008 11:57 AM |
| Tire and Wheel Combo | RandoGT | 96-98 | 10 | January 7th, 2008 05:30 PM |
