1991 Ford Mustang GT
ajustable clutch cable, fire wall ajuster and quadrant
I think my clutch cables worn out, so i was just looking around, and i must have been living under a rock but have you all seen and used the 2 and 3 position quadrants...if you dont know what im talking about heres a link
Whats the point of the exra positions ? Any feed back on them ? I already have an aluminum quadrant but its the normal one position style. Also if i install a fire wall ajuster, do i need to remove the black rubber bushing from the clutch cable ? ( the part that normally rest on the fire wall ) Any advice weather to get an ajustable cable with the fire wall ajuster or a non ajustable cable with a fire wall ajuster ? Im leaning towards both be ajustable, seems like id get more life out of the cable Any advice on which brands to get, would be helpful Thanks
Mustang Fanatic
1989 Mustang LX
The Maximum Motorsports, And Ford Racing cables have both been good to me...
i personally use the FRPP one still and it is adjustable. same with the MM one. I believe the positions on the quadrant change where the clutch grabs. example, if you put the cable on the first hook, closest to driver, then the clutch will grab with pedal closer to the floor. if you set it on the second hook, itll grab closer to the pedal being halfway off the floor..
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
meh
The steeda quadrant I have has 2 hooks. If you are using the cable that adjusts at the end under the car, then you use the hook at the end of the quadrant (you have to pull more cable to hook it).
If you use the same adjustable cable and you have a firewall adjuster too, the cable is going to be shorter (because the adjuster is taking up that extra length) and you have to use the hook that's closer to the front of the quadrant (don't pull cable as far to hook it). This is my best guess. The stock cables are not adjustable.. that's because the stock quadrants were ratcheting quadrants.. when the cable was loose, you could pull up on the clutch pedal, and it would ratchet up, thus tightening the cable. But the stock quadrant is junk.. it's plastic, and 20+ year old plastic is really brittle. Add a fresh heavy-ish clutch, and it'll snap.
'87 2.3 Notch with +4 cylinder mod ![]() Ass, Cash, or Grass.. nobody rides for free Black Stang Crew Member #11 |
Oh....
When i put in my new engine i just reused the old ajustable cable. When i have the nut tightened more then half way the clutch doesnt grab untill the pedel is all the way up. When i have the nut all most all the way out it grabs when pedal half way up, which is normal, but im running out of threads, to loosen the nut, not sure if im ajusting it wrong or its a sign of the cable needing to be replaced. From some of the videos ive seen on youtube it shows the nut on the cable being in the center of the threads. Any way thanks for your input alex and notcho, does any one else have advice or answers to my questions.
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
I use the ford racing cable (adjustable at the trans)
I have an aluminum quadrant. (brand unknown - it was there when i got the car) I don't know what hook I'm using though as my buddy installed that side for me.... he was bored and wanted to do it. I also have a fire wall adjuster. (brand unknown - it was there when I got the car) I cut the rubber bumper thingus off of it (the part that would sit against the fire wall) and let the white-ish piece rest against the adjuster. I would say that I am at mid-adjustment under the car. The fire wall adjuster is nice because it lets you adjust the cable for stretch and clutch wear without getting under the car. |
maximum motorsports is the only aftermarket cable and quadrant ill use again.
#7 | |
The Big Spoon
never fast enough
Sounds about where mine is adjusted to. If I were you, I'd leave it be and have a spare cable on standby. That's how I roll. If you look around at quadrants, you'll find a company that went out of their way to make a smooth transition for the cable at the quadrant. Many quadrants have a sharp edge that can cut into the cable. When you do get a quadrant, you may even be able to radius the transition yourself w a dremel.
Good to know...
1987 5.0 GT
#11 | |
![]() iTrader: 1 reviews
As for adjustment - the kit Speed Unlimited is offering is perfect for you - sorry for the delayed reply |
Use whatever hook and whatever cable setting (ford cable is the best). What matters is that you have about a dimes width of free play in the cable at the firewall adjuster when correctly adjusted. If there is any preload on the clutch it will cause multiple issues. Having a tiny bit of slack ensures good air gap when you push the pedal in and will make sure the clutch is fully engaged when you let off the clutch. Too much slack will obviously cause issues with disengaging. It amazes me how many people mis adjust their clutch because they like the way it feels when it engages at a certain pedal height.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
DILLIGAF
Good info !!!
#14 | |
Thanks
ford cable is better, other cables may work.
well documented problems with some cables not being as strong or stretching significantly. besides with a firewall adjuster, you don't need an adjustable cable. And as a rule of thumb, always do your homework when someone is trying to sell you something.
ryan I know you use the ford cable, which quadrant and adjuster do you use?
Right now i have an ajustable cable of unknown brand.... no fire ajuster
I do have the aluminum quadrant. How far off the floor should my pedal be for the clutch grab with the set up i have now ?
Sorry man I meant the other ryan. As for your question I would think no matter the set up it should always grab in the same spot if it is correct. I far from a expert in the matter though. Im usually a C4 guy.
Threads Similar to: ajustable clutch cable, fire wall ajuster and quadrant
| clutch quadrant and cable install | Blk01ponyGT | 99-04 | 16 | March 10th, 2008 09:17 PM |
| Clutch Cable And Quadrant | 99stangman | 99-04 | 2 | November 20th, 2007 01:30 PM |
| Clutch cable and Quadrant | 99stangman | V6 Mustangs | 2 | November 19th, 2007 12:58 PM |
| upr clutch quadrant and fire wall adjuster | ujslost | Parts | 0 | April 18th, 2007 11:32 PM |
| Clutch Cable \ Quadrant Help Needed | jrhurst | Modular Mustangs | 4 | April 12th, 2007 02:02 AM |
