5.0 won't run!!
Old January 26th, 2012, 01:46 PM   #1
1984 stroker
1984 mustang L
1984 stroker is on a distinguished road
5.0 won't run!!
I have an 84 5.0, it's got an edelbrock intake and edelbrock 650 carb. My car died driving down the road and will not start again. Here's what's going on, the car turns over and starts but immediately dies. I've replaced the plugs, battery, ignition coil, cleaned all grounds, rebuilt carburetor, still nothing. I'm getting spark, it's getting steady fuel ( I can see it in my inline filter). What could be causing my motor to immediately die out like that? Any help would be great!
Old January 26th, 2012, 03:04 PM   #2
01V8MUSTANG's Avatar
01V8MUSTANG is on a distinguished road
Have you tried pulling the fuel line from the tank and trying to feed from a gas can? If you operate the throttle with the air cleaner off and looking into the carb, do you see fuel squirt in the bores? Whats your fuel pressure at? Does it run off of a can of ether?
Old January 26th, 2012, 09:10 PM   #3
1984 stroker
1984 mustang L
Yes, the carb fuel pumps are squirting. I rebuilt the carb so everything there is in spec and cleaned. I've tried running it by pouring gas in and still nothin, same with ether. Sometimes it'll even just catch my carb on fire. I'm stumped and it's very frustrating!!
Old January 27th, 2012, 06:52 PM   #4
Sounds like an electrical issue then. Timing is on? Did the ignition module burn out?
Old January 29th, 2012, 12:30 PM   #5
1984 stroker
1984 mustang L
The car ran fine with the distributor the way it is now, I didn't mess around with timing besides just turning it a little bit in either direction. Is it possible for an ignition module to burn out while just driving down the road? And that would keep it from running at all? This is my first project car and I'm kind of teaching myself by researching and reading. Thanks
Old January 29th, 2012, 01:09 PM   #6
e3sean's Avatar
1988 lx
9.68@142
yes anything can fail at any time. pull the coil wire off the distrubitor and put a screwdriver in it and next to a ground turn it over and see if its getting spark.
<font size=4><b>MILITARY CREW
Old January 29th, 2012, 01:11 PM   #7
e3sean's Avatar
1988 lx
9.68@142
if you havent change anything and its getting air and fuel then its not getting spark... thats all there is to it..
pull a valve cover off and see if the rockers are moving.... maybe you broke the timing chain.
Old January 29th, 2012, 01:19 PM   #8
1984 stroker
1984 mustang L
I've replaced the coil, I've pulled number one spark out and it is getting spark, if my ICM was bad would I still get spark?
Old January 29th, 2012, 07:24 PM   #9
I aree with e3sean,pull VC's off. I would double check everything listed.
Old January 29th, 2012, 11:24 PM   #10
1984 stroker
1984 mustang L
Thank you e3 and 01 v8. First time I got my car running since August. It was a bad ICM. Thought they were much more expensive that's why I hadn't replaced it. Picked one up for 35 bucks at autozone and the stang is running like new! Now I'll start my body work! Thanks guys!
Old January 30th, 2012, 05:46 PM   #11
Glad to hear you're up and running again. When I had my old truck I carried a spare ICM with me just because I had one quit like yours did.
Old January 30th, 2012, 05:48 PM   #12
1984 stroker
1984 mustang L
That's not a bad idea, thanks again
