Ac bypass
I need help bypassing the ac. I need to know how to get the belt on and what do I need to take off to get it on.
Mustang Fanatic
1989 Mustang LX
Get the AC delete kit from latemodelrestoration.com.
Cheap and comes with everything needed
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
1991 Ford Mustang GT
What is your question, do you want to remove your a/c system or are you having trouble putting the belt on ?
I'm having troube putting the belt on
Theres a tensioner pulley
put a socket and breaker bar on the pulley bolt and push down... that will raise the spring loaded pulley enough to slide the belt on then release the pulley, and your ready to go....it takes 10 sec to do
Threads Similar to: Ac bypass
| amp bypass in 00 | 02edge | Audio/Video | 8 | June 11th, 2011 01:52 PM |
| Fan Bypass | Foxmoto28 | 94-95 | 0 | September 15th, 2010 06:04 AM |
| BOV or Bypass ??? | SilverGT04 | 99-04 | 8 | August 16th, 2009 11:05 PM |
| EGR Bypass? | futureMACH1racer | 4V / SVT | 18 | April 7th, 2008 01:21 PM |
| SC Bypass | jdm2007 | 2005 - 2010 | 13 | May 6th, 2007 06:46 AM |
