Valve spring removal
Old January 26th, 2012, 11:40 PM   #1
Ohsplat's Avatar
1983GT
No motor or trans
Ohsplat is on a distinguished road
Send a message via Yahoo to Ohsplat
I have one of those Twist down type of valve spring removes and it will not work on twisted wedge double springs. Is there a trick to this? I was thinking I could weld something to a c-clamp and use it?
What do you guys use?
Old January 27th, 2012, 12:01 AM   #2
fogged306's Avatar
89 GT
It'll work. I have triple springs that are 400lbs open on my TW heads and I used that type of compressor. It can be a bit of a pain in the ass, but it will get the job done.
Old January 27th, 2012, 12:26 AM   #3
Ohsplat's Avatar
1983GT
No motor or trans
it seems to only grab the 1st spring
I have one similar to this one.
Old January 27th, 2012, 12:32 AM   #4
fogged306's Avatar
89 GT
Yea it will only grab the outer spring. But the inner springs are weak enough that you can push them down by hand, or take a hammer and give the tool a tap straight down to release the locks.
Old January 27th, 2012, 12:35 AM   #5
Ohsplat's Avatar
1983GT
No motor or trans
oh.... right on. thanks man!
Threads Similar to: Valve spring removal
Valve Spring Removal WickedSnake00 4V / SVT 26 April 27th, 2011 04:14 PM
alternate valve spring removal method BlueDevil 2005 - 2010 13 March 26th, 2011 10:29 PM
spring isolator removal opinion will2045 99-04 9 August 13th, 2010 11:30 PM
clock spring and module removal... bryand 94-95 0 August 11th, 2009 06:20 PM
Valve Spring removal acmillr 99-04 0 January 7th, 2007 09:53 AM
