1991 Mustang GT 5.0
need help with legendary idle issues!!
Alright so 1st off its a totally stock 91 GT auto. Has 123k miles. It was driving perfect then I stopped at a stop light longer than usual and rpms suddenly dropped. Almost like it is on the verge of dying. It does this when I start up and when I stop and idle for to long. I have had problems with the iac and I already replaced that. Any suggestions are greatly appreciated!
1991 Mustang GT 5.0
OK well I just changed tps. Problem still there. It takes it about a minute to actually drop rpms
1992 Mustang LX
13.0 @ 105
Check for vaccuum leaks.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1991 Mustang GT 5.0
Already did. That's the 1st thing I checked for. It happens about 1 min after stopped. I'm totally stumped. Also I cleaned the MAF. still no change. I need ideas.
1992 Mustang LX
13.0 @ 105
Clogged cats? I'm bad at diagnosing stalling issues.
1991 Mustang GT 5.0
Not running cats. Got o/r h-pipe. Sorry I forgot to mention. But other than that its stock.
1991 Mustang GT 5.0
Thanks for the suggestions guys.
1992 Mustang LX
13.0 @ 105
Hows your tuneup? Plug, wires etc.
1992 mustang Lx
13.4@ 106
Good place to start.
Mustang idle surge and base idle reset If you just put the new tps on and didn't calibrate it I would check that first.
![]() 1992 5.0 lx_soon to be powered by a m122 GT500 supercharger
1991 Mustang GT 5.0
Just did a tune up about 500 miles ago. And calibrate the Tps? I set it at .98 volts.
You could try replacing your ECT and ACT sensors.
1988 Mustang: 5 speed, hurst shifter, plenty slow. |
1991 Mustang GT 5.0
Just changed ECT. PROBLEM GONE!!!!
1993 Mustang GT
When you said you changed your ECT,where is it actually located?im having the same problem.is it in the hose by the Intake?
Sent from my Autoguide iPhone app
1993 Mustang GT (Reef Blue on platinum) 105k Miles, still strong. BBK CAI Dual Flowmasters Hurst Shortshifter Smog Delete Gatorback pulleys. FULL LED Tailights NEWEST ADDITION: Eaton M90 supercharger kit |
1991 Mustang GT 5.0
Yes. Its on the metal tubing its right by injector number 4 I believe. Its right on top. Took me 10 min to fix. Also make sure you check all vacuum line thoroughly. Spray starter fluid all over engine. Compartment ment. One place at a time. Have to cleaned IAC AND MAF?
1993 Mustang GT
No but I have an aftermarket CAI and it's relatively new with the MAF so I figure it's my ECT because it only does it on cold mornings.
1991 Mustang GT 5.0
OK. Well I hope that fixes your problem as well. Please let us know. Your answer may help others
1993 Mustang GT
I just went and picked mine up,and installed it,I'll post tomorrow morning letting you know if it worked!
1991 Mustang GT 5.0
Alright sweet!!
1993 Mustang GT
Now it's throwing a check engine light...could this be from tightening the bolt to tight/frayed wires?what do you guys think?
1991 Ford Mustang GT
Pull the battery cable for 30 min, it should reset the computer, see if the cel comes back
If it comes back, run your codes
Threads Similar to: need help with legendary idle issues!!
| idle issues HELP! | kyle2002stang! | 99-04 | 10 | November 4th, 2011 11:52 PM |
| Idle rpm issues? | Maluther | 2005 - 2010 | 2 | September 3rd, 2009 11:25 AM |
| Idle issues | Novanutcase | 99-04 | 2 | April 15th, 2009 08:02 PM |
| Aftermarket TB/Plenum hanging idle/low idle issues! | Novanutcase | 99-04 | 12 | August 13th, 2008 11:24 AM |
| help help help (Idle Issues) | joe 5.0 | 5.0 Mustangs | 4 | April 19th, 2007 08:50 PM |
