1989 Mustang LX
Intake problem
Hey guys got a question for ya! I got an 89 notch with the stock 5.0 upper and lower. The issue is the fitting for the PVC coming off the intake is hitting the valve cover. What would be the best solution for this besides a spacer?
Sent from my Autoguide iPhone app |
#2 | |
1991 Ford Mustang GT
Im guessing you meant to say PCV and not PVC......lol im just playin.... Can you post a picture ?
1988 lx
9.68@142
is the rubber in good condioion?
is the valve working? pick it up and shake it see if its ratteling. try cleaning or replacing it. the engine could be over pressurizing and pushing the valve out.
Threads Similar to: Intake problem
| Cold Air Intake Problem | steve18 | 2005 - 2010 V6 | 4 | October 21st, 2011 04:53 PM |
| PI intake problem? | NatesGT | 96-98 | 2 | March 14th, 2011 10:00 PM |
| 302 intake manifold problem | Moosestang94 | Classic Mustangs | 2 | October 25th, 2010 04:03 PM |
| problem with steeda intake | roxas331 | 2005 - 2010 | 9 | May 27th, 2009 12:31 AM |
| cold air intake problem | BWAL | 5.0 Mustangs | 1 | August 30th, 2008 09:49 PM |
