1 Wheel Peel
2000 Mustang 393w
2001 Mustang GT Vert
Retrofitting an elderly block to a roller block
I know I had a lifter/Valvetrain thread a while back.
Anyways.. I have a 80-83 block and looking to retrofit the block. My main question is "If retrofit is essentially the same as link bars" I am looking for a solid roller kit. Either I am blind or there aren't any comp cams "retrofit" lifters that are solid roller. I fould a set of Scorpions but am clueless on the reliability of them. Any links or recommendations as to them. The max lift on the cam is .680
![]() 2000 393w Swapped Vert 2001 GT Vert 2002 Six Banger |
89 GT
Just use linkbar lifters. That way you don't need to do anything like drill and tap the block and use a small base circle cam. Just use any roller cam you want.
Ok re-reading, I missed the question. Technically retro-fitting involved what I mentioned which is drilling and tapping the block, using a lifter hold down and dogbones like a stock set-up, and a smaller base circle cam. Using link bars will allow you to put a roller in a non roller block as well but I don't believe they refer to it as retrofitting.. could be wrong. Either way, link bars are the way to go. There's tons of solid link bar lifters to choose from. I would post links but am using the phone. |
1 Wheel Peel
2000 Mustang 393w
Thanks.. Retrofit lifter kits appear to be a pair of lifters with a non-adjustable linkbar. Nothing to do with drill and tapping
1988 lx
9.68@142
agreed
you would need to retrofit the block for the dogbones and spyder that holds them cause a hydrallic roller lifter does not use linkbars but if you are going solid roller that is just a new cam and lifters. dont skimp on valve springs ither.
1 Wheel Peel
2000 Mustang 393w
I got valve springs exactly on spec for the cam, as well as retainers and rockers already. Just need lifters and pushrods.
1988 lx
9.68@142
comp solid rollers would be a good choice
1 Wheel Peel
2000 Mustang 393w
How about Howards, Or Lunati. They are a tad cheaper.
I know you get what you pay for but doesnt hurt to see how people have done with them Edit: just read bad reviews on both. These are the comp cams http://www.summitracing.com/parts/CCA-838-16/
89 GT
Are you running this car on the street? Take this for what it's worth because I've never run into this personally, but a pretty respected builder told me this, solid rollers can have trouble idling. Apparently the pin oilers don't get enough pressure at idle and the bearings can wear prematurely and fail. I don't understand why that is personally, but this guy builds a lot of fords and I tend to believe him. I asked him about crower hippo lifters (hi pressure pin oiler) to see if maybe those helped but never got a response to my question. At the same time, I've seen a few guys run solid rollers on the street and never complain about a failure so who knows. I haven't looked much further into it because I don't plan on running solids for a while yet now, but it may be something worth checking into before you buy.
1969 Mustang Mach 1
6.824@101.61
The Crower setup seems to be the best way to go for solids on the street. Something about the way they're oiled or something. BUT they are $$$$$$$$$
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1 Wheel Peel
2000 Mustang 393w
Fogged,
It will be a street driven car, about once a week. Lol. A few buddies are running solid rollers and have never had a complaint from them. I will look into that more.
1 Wheel Peel
2000 Mustang 393w
Indeed they are, what do you run for a lifter?
1969 Mustang Mach 1
6.824@101.61
Mine are hydraulic, and in a roller block. I run a stock style setup, with some comp lifters.
Threads Similar to: Retrofitting an elderly block to a roller block
| roller cam in non roller block HELP! | smoke98gt | 5.0 Mustangs | 5 | September 13th, 2011 08:09 AM |
| free 351w roller block. | JBIGBOOTSY | 5.0 Mustangs | 15 | March 2nd, 2009 07:01 PM |
| roller block vs non roller | 01dutchGT | Classic Mustangs | 5 | January 27th, 2009 08:40 AM |
| Production roller block @ 1100 HP | Zak | 5.0 Mustangs | 10 | April 24th, 2007 08:50 AM |
| roller vs. non roller block | DJKING | 5.0 Mustangs | 11 | March 29th, 2007 11:53 AM |
