sun roof leak
Old January 28th, 2012, 09:12 PM   #1
1993 Cobra #2420
1993mustang cobra #2420
mdayz28 is on a distinguished road
sun roof leak
Was wondering how much of a project it is to change the sun roof drains on my 93 cobra ? I have to change my passenger side floor board because of I was told my drain to my sun roof needs to be replaced . Does anyone know where I would be able to buy new drains ? I was told you cannot blow them out with air because if they are brittle they will come apart . Would appriciate any information , THANKS!!
Old January 28th, 2012, 09:33 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
http://forums.corral.net/forums/gene...ain-holes.html
Ford Mustang : The Corral is the oldest and best known Ford Mustang website on the internet! Meet new friends, get excellent technical advice. - Search Results for sunroof drains
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 29th, 2012, 12:52 AM   #3
1995 Mustang GT
However fast it can be pushed or pulled.
95_gt is on a distinguished road
I have ran into this at work before. If you plan replacing them anyways, go ahead and try the air. If it breaks then you will just faced to replace it. If it doesn't and it actually cleans it out then it will save you some money. The best thing to do would probably to go get a long skinny soft bristled pipe cleaner brush. Domed times forcing water down them will clear a clog out too. Good luck.
Old January 29th, 2012, 08:42 PM   #4
1993 Cobra #2420
Thanks for the information , also that is a very nice looking gt you have!
Old January 29th, 2012, 08:45 PM   #5
1993 Cobra #2420
Just noticed your car has no pic. with it , I thaught the car above was yours , but thanks for the information !
Old January 29th, 2012, 09:23 PM   #6
ryanw's Avatar
Are you talking to me? If so the silver gt is mine
255 fuel pump,
3:27 gears
Old January 30th, 2012, 06:45 PM   #7
1993 Cobra #2420
Yes very nice GT , also my latest info. is that when I took it to a body shop today the guy told me that he does not think the leak that rotted out my passenger side floor pan was caused by the drains but by the A/C drain being clogged and over-flowing onto the floor.Also thanks for the other site you gave to me !
Threads Similar to: sun roof leak
roof leak Mustang03 99-04 8 January 18th, 2010 10:32 PM
a sun roof? 03stanggg V6 Mustangs 12 July 1st, 2009 08:15 AM
New Roof winnie51189 Visual 26 November 5th, 2008 03:34 PM
t bar roof Hourofpain The Clubhouse 22 September 27th, 2007 02:12 AM
Evaporative Emission System Leak Detected (very small leak) Juggalo_X V6 Mustangs 11 April 25th, 2007 04:46 PM
