Question on some tire sizes
Old January 30th, 2012, 11:27 AM   #1
SideStep302's Avatar
1991 Mustang GT
SideStep302 is on a distinguished road
I have a 91 gt. I have cobra r 17" rims on it. I wanted to get some rear tires that I can use on the street and the track. The tires will be mounted on the 17" cobra's. Wondering what size and what my best bet is. E/T Streets or? Thanks for your help!
(i tried searching for this but couldn't seem to find anything. So if this is an existing thread I apologize)
Old January 30th, 2012, 11:48 AM   #2
06 mustang GT
12.8
06GreenMachine is on a distinguished road
Do you know the width of the rim? That will pretty much decide the size that will work on those rims
2006 Mustang GT 5-Speed,4:10 gears, Predator cold air and tune, SLP loudmouth exhaust,kooks LTs and Xpipe 275 street tires, FRPP hot rod cams, mgw STS, 1/2 inch drop,285drag radials, Steeda UDP's, 100 shot.
Old January 30th, 2012, 11:53 AM   #3
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Cobra Rs are either 8s or 9s (there's both), which means typically 245/45s or 275/40s, respectively.
How long do you expect these tires to last? Are you okay with replacing them in 5k miles, or do you need something that you can put more mileage on?
Is this a DD or a weekend toy?
O o
/¯/______________________
\_\
Old January 30th, 2012, 02:30 PM   #4
1991 Mustang GT
It is a 9" width. It's only a weekend toy. I probably put 5k on it a year. I didn't take the quad shock out or anything. Ill only take it to the track a couple times a year but I'm just sick I constantly spinning tire. Only goes on the highway a handfull of times. What's the best bang for my buck? Basically, what I'm trying to avoid is buying a separate set of rims and slicks. Thank you!
Old January 30th, 2012, 02:39 PM   #5
Considering that it's still a street driven car, I'd be looking at a drag radial, like the NTO5R, 555R, etc.
I'll let the drag racers chime in, as DRs are really outside of my area of enthusiasm
O o
\_\
Old January 30th, 2012, 04:14 PM   #6
1991 Mustang GT
What are my size options knowing that it's a 9" rim? Thanks for any input
Old January 30th, 2012, 04:20 PM   #7
Generally speaking, you can use a section width that's anywhere between about 100% and 125% of the wheel width, with factory sizing typically being right at 120%
So for 9", that's 228.6mm wide, so you're looking at anything from a 235 to a 285, with 275s being factory. Some guys say you can go all the way up to 130% of the wheel width which'd be a 295.
And of course, fudge the numbers based on how the tires run. If it's a known-narrow tire, bump it up a size, if it's a known-wide tire, bump it down.
O o
\_\
Old January 30th, 2012, 07:07 PM   #8
1991 Mustang GT
ive been looking around and i found these.
Hoosier 275/40/17 Drag Radial [HOO-17330] : Lethal Performance, Performance parts for Ford Mustangs
Do you think i can go a little taller like a 275/45? or a 275/50? or will i be rubbing? i'm new with buying tires like this! haha
Old January 30th, 2012, 07:49 PM   #9
fogged306's Avatar
89 GT
I use these on my 17" cobras. They hook very well, but don't do well in the rain. Also keep in mind that a DR is pretty sticky when warm, so if you fuck around on the street a little, they'll pick up every little stone they roll over and fling them into your wheel well.
Old January 30th, 2012, 10:02 PM   #10
1991 Mustang GT
Do you happen to have a picture of your car with them on? I want it to look full under the wheel well. How long have those lasted you? ish?
Old January 31st, 2012, 11:28 AM   #11
fogged306's Avatar
89 GT
I've only had them on since this summer so I couldn't tell you how many miles you'll get out of them. Car is lowered. Never measured how much from stock though, it's on coilovers.
Old January 31st, 2012, 07:51 PM   #12
1991 Mustang GT
that looks awesome. Do you think you could get any taller in the back or is that pretty much as much rubber and youre going to fit in there?
Old January 31st, 2012, 08:30 PM   #13
fogged306's Avatar
89 GT
I can get more height tire in there if I wanted to. That's a 26" tire. A 28 shold fit no problem even lowered. I did roll my fender and I have no quads or tail pipes.
Old January 31st, 2012, 08:36 PM   #14
Mustang Fanatic
ALEXLOPEZ62188's Avatar
1989 Mustang LX
ALEXLOPEZ62188 is on a distinguished road
Tail pipe clearance also varies between companies.
I know some flow master clear. My Mac 3" clear a 285/35zr18 with about an inch to spare.
No quad shock tho
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old January 31st, 2012, 11:09 PM   #15
1991 Mustang GT
I have no tailpipes either. Too bad they dont make those Hoosiers I posted in a 28. I'll be honest, I really like the white logo's such as hoosier or M/T written on the side. Kind of stupid reason to like tires but... Can't find many other drag radials with the big white lettering!
Old February 1st, 2012, 09:16 AM   #16
El Conquistador
whiteboycustom's Avatar
83 coupe
whiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nice
Send a message via AIM to whiteboycustom Send a message via Yahoo to whiteboycustom
275/50/15 MT DR......
http://www.donttearmedown.com/
Old February 1st, 2012, 12:00 PM   #17
shamrock81887's Avatar
1993 mustang gt
stock
shamrock81887 is on a distinguished road
F:235 45 17 R: 275 40 17 (17x8 front 17x9 rear )
Threads Similar to: Question on some tire sizes
Tire sizes Airmandavis 99-04 9 August 3rd, 2011 08:44 PM
question about tire sizes. blue03mach1 4V / SVT 19 February 15th, 2009 11:02 PM
tire sizes hmargov1 99-04 7 March 7th, 2008 10:47 PM
question about rim/tire sizes red99geetee 99-04 20 February 9th, 2008 01:17 PM
What tire sizes to get? BumbleBeeStang04 99-04 24 March 4th, 2007 12:36 PM
