best compression for boost - Page 2
Old February 1st, 2012, 11:50 AM   #21
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
Originally Posted by ReverendDexter View Post
I'm surprised no one's mentioned fuel. There's a difference in what compression ratio you're gonna be able to run if you can only get/afford pump gas vs if you can run e85 or 100+ octane race gas.
Unless someone mentions E85 or race fuel I assume they are thinkin pump gas. Most people that are serious enough to use e85 or race gas know to mention it and/or arent asknig these kinds of questions.
Old February 1st, 2012, 12:43 PM   #22
VM0824's Avatar
1989 Mustang GT
~14@99 (b4 turbo)
VM0824 is on a distinguished road
I didn't have any detonation before with the stock 9:1.
306 w/ 8.9:1
ON3 70mm turbo kit - 9#'s boost
arp chromoly studs
47# FRPP - 255 walbro
3.73 - tremec 3550 - zoom hp kevlar clutch
msd 6a + blaster coil
lowered. sfc. HID
delete egr-smog-cats-a/c-foglights
battery reloc
QuarterHorse, BE, EA
Old February 1st, 2012, 02:07 PM   #23
BassMaster5000's Avatar
'90 Mustang GT
BassMaster5000 is on a distinguished road
Originally Posted by VM0824 View Post
ive been trying to calculate it myself, but i called the shop and told them to aim for 9:1 and to calculate piston volume from that.
very cool thoery. i kind of figured that CR was some arbitrary calculation that correlated to some real math. with that in mind, the stock cam on my 89 is fairly "small" no? so the DCR would be fairly close ?
Since you have the stock cam, the seperation isn't as significant such as on a custom ground cam for boost. This just means that your intake valve closes, causing combustion earlier in your cyclinder, than if you had a different cam for instance.
I think everyone is just trying to throw out preventive measures to insure that if you up the boost in the future, that you don't have any problems. You can always consider changing cams/pistons/heads/headgaskets, or going to e85/c16/meth injection, but I personally feel you will be fine. This isn't like your adding 15#s to a motor with a 11.5:1 CR.
90 Gt- 331 Stroker, Forged Internals, TW Ported Heads, 30# Injectors w/ adjustable Kirban Fuel Pressure Reg, CI Custom Cam, Holley Systemax, 70mm Accufab TB, 75mm ProM MAF, BBK Fenderwell.
Dyno'd at 342/364 best E.T. is 12.8/109.
Threads Similar to: best compression for boost
Compression+Boost? 93slayer 5.0 Mustangs 6 March 17th, 2011 08:07 AM
Most boost with 9.5:1 compression DegralDan 99-04 19 February 17th, 2011 11:52 AM
Compression for boost? bandity2k00 99-04 21 January 19th, 2010 09:40 AM
can i boost high compression? skuba Modular Mustangs 10 October 12th, 2009 04:01 PM
Low Compression High Boost? e3sean 5.0 Mustangs 19 November 19th, 2007 01:13 PM
