s trim supercharger
im looking at a s trim supercharger its a bout 80 percent all there and its a 1000 dollar is that worth it? an would i see a lot of power differents? i have 306 afr heads e 303 cam but the only things its was for a efi an my carbs so how much trouble would that be to get it to work other then the blow thru carb
1991 Ford Mustang GT
I think youll just need a carb hat, to make it function on your set up
What is the supercharger missing, how many miles ? a 1000 doest sound bad, if you can get the missing parts for 400 or less
12.41@114
Carb hat and a blow through carb for it to work correctly. Blow through cards are pricey.
MM FOBRA CLUB CO-FOUNDER
yea is that all tho just the super charger and bracket for it, i wouldnt need a new fuel pump for pressure an wat all does a kit come wit do i need anything for the timing and stuff like that
The normal kit comes with
Supercharger Supercharger pulley Crank pulley Supply and return oil lines T fitting for the supply oil line Air filter, Inlet and discharge tube Inner and outer mounting brackets Idler pulley Alternator stay bracket Belt Nuts, bolts, washers and spacers. Hose clamps Radiator exstender metal hose And in some cases, fmu and lines and upgraded fuel pump, by pass valve 1986-1993 Ford Mustang 5.0L Supercharging Systems | Vortech Superchargers
#8 | |
Fyi..rebuilds im told are between 600-800 dollars, so hopefully it doesnt need one
Threads Similar to: s trim supercharger
| v2 s-trim vortech supercharger | Slow89hatch | 96-98 | 1 | March 6th, 2011 09:18 PM |
| New Vortech T-trim supercharger | AnimalCrackers | General Tech | 5 | July 17th, 2008 03:28 PM |
| vortec V-2 SQ S-Trim supercharger | show95stang | 5.0 Mustangs | 7 | March 1st, 2008 10:20 AM |
| Chance to Land a Vortech V1 T-Trim Supercharger CHEAP!!! | Speedstang302 | 5.0 Mustangs | 2 | August 28th, 2007 01:45 AM |
