Fresh 306 combo for my 82 Capri
LinkBack (1) Thread Tools
Old January 30th, 2012, 02:56 PM   1 links from elsewhere to this Post. Click to view. #1
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
I've decided to build a fresh 306 for my 82 Cari RS. I've built a couple 347's and a 331 in the past, I've decided to try a nice 306 this time. So far I've picked up a used rotating ass. in nice condition that consists of stock HO crank & rods(rods have been resized w/ ARP bolts) ROSS flat tops w/ TW vavle releifs, all balanced to 50oz, Anderson N41 cam, I've got a new set of TW 170's at Fox Lake for their stage 1 port/vavle job & milled to 58cc, RPM air gap intake, 650 HP Quick Fuel carb, full MSD ignition, BBK 1 3/4" long tubes & full exhaust, RAM dual friction clutch, fresh 89 T5, 8.8 w/4.10s. The car already has full length weld in subframes, Hotchkiss rear control arms, air bag in the RR, front sway bar removed, etc. I'd like to keep it a nice driver and get as far into the 11's as possible. Any comments/feedback?
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old January 30th, 2012, 03:05 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
Pictures of car before build begins, please...
How about converting it over to fuel injection, that would be an awesome build thread
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 30th, 2012, 03:33 PM   #3
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Why not go with the N51? Do you still want good driveability? That's about the only thing I'd change on that setup...And I'd switch over to EFI while I was at it, but that's just me Since you're staying carb, why not grab a victor jr. intake? You can get em used near me for 100-125$. That's a steal in my eyes. Plus it's an improvement over the air gap.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old January 30th, 2012, 03:36 PM   #4
1992 Mustang LX
13.0 @ 105
When will this be done by? I wanna see if the 302 I'm putting together will be any faster...Wanna make a bet? I'm using the stock bottom end with new rings ARP rod bolts and the rest is stock. Using a 20* head though. Good luck on your build
Old January 30th, 2012, 03:46 PM   #5
My origanal plan was to EFI it and add a Novi 1000 or Vortech S-trim. I'm going to stick with the carb for now, because I like the orignal under hood look(plus it makes people wonder when the car is running fairly qiuck). Down the road after I finish a couple other projects it might get EFI. BTW the car weighs 3100 with me in it!
01 Ram Quad Cab
03 Grizzley 660
Old January 30th, 2012, 03:51 PM   #6
It won't be done until June or July. Dropping the block off tommorrow for machine work. I just got a call from Ron at Fox Lake, he is shipping my heads out today. I have a Vic Jr. waiting in the wings. I want to see how it runs with the air gap then maybe switch to Vic Jr. I'll be driving this alot, so I want to keep it kind of mild. I've also got a N61 laying around, I might do a cam & intake swap to see if it improves!
01 Ram Quad Cab
03 Grizzley 660
Old January 30th, 2012, 03:56 PM   #7
1992 Mustang LX
13.0 @ 105
I was going to suggest using the N61, but you're not really spinning it that high, right? N61 is more for the 6800-7200rpm shift points...N51 would be good. Try out the 41 and see how it goes. Then swap to another stick along with the victor jr and see what it gains.
My build will be finished around the same time! Let's see who has the faster small cubes, stock bottom end (for the most part) car! I will also weigh about the same...Maybe 200 pounds lighter. Same exhaust, gear and tranmission too
Old January 30th, 2012, 03:59 PM   #8
ryanw's Avatar
Is that the oiginal hatch glass, cuz i thought the capri had the big ungly bubble glass ?
I know your not going to do this, but i love when there converted over to look like a mustang, just leaving the squared off fenders,with the 87-93 quarter glass with either the 85-86 front nose and tail lights or 87-93 front nose and lx tail lights
255 fuel pump,
3:27 gears
Old January 30th, 2012, 04:21 PM   #9
82 was the last year of the Mustang hatch. 83-86 had the bubble hatch, which I'm not a fan of. I just saw a notch roller the other day that had Capri quarters & front fenders with 87^ front nose, it looked pretty cool. I'm all about the OE look, so mine's staying as is.
01 Ram Quad Cab
03 Grizzley 660
Old January 30th, 2012, 04:30 PM   #10
I was just on the Anderson website and they list the N41 for 2600-6200 rpm and the N61 2500-6500. The specs are not that far apart N41=222/232 512/512, the N61 is 228/236 544/568 both with 1.6 rockers. I've got 1.7s for the N41 so lift will be 544/544. I'm going to stick with my orignal plan and go from there. Only problem for me is the closest 1/4 mile track is 300 miles away!
01 Ram Quad Cab
03 Grizzley 660
Old January 30th, 2012, 04:36 PM   #11
1992 Mustang LX
13.0 @ 105
I live out on Long Island (60 miles from NYC) and the closest track is ATCO! >.<
Old January 30th, 2012, 04:37 PM   #12
1992 Mustang LX
13.0 @ 105
So, I feel your pain.
Old January 30th, 2012, 04:50 PM   #13
Luckly I've got an 1/8th mile track just 5 miles from my doorstep! So I do alot of 1/8th mile racing!
01 Ram Quad Cab
03 Grizzley 660
Old January 30th, 2012, 05:00 PM   #14
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Nice build. I like it. With the air gap, I think the 41 is a great match.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old January 30th, 2012, 05:03 PM   #15
Thanks. I'm hoping its nice & streetable and lay down some serious times at the track! I got to get some paint on it next!
01 Ram Quad Cab
03 Grizzley 660
Old January 30th, 2012, 05:19 PM   #16
1992 Mustang LX
13.0 @ 105
You have an E.T goal for it? I can see 11.50s or a little faster with tuning and a good driver
Old January 30th, 2012, 05:30 PM   #17
11.50 should be an acheivable goal, kinda what I had in the back of my head. I've been banging gears with stick cars since the 70's, so I'm not too bad at it. Probably gona ditch the AC stuff when I pull the motor that's in there now, to try and save a little weight.
01 Ram Quad Cab
03 Grizzley 660
Old January 30th, 2012, 05:34 PM   #18
1992 Mustang LX
13.0 @ 105
A/C shit doesn't weigh all that much, but I took mine out anyway, lol. Post a video of you taking your car for a rip! Unless it's apart right now...lol.
Old January 30th, 2012, 06:03 PM   #19
Right now it's got a 114,000 mile 89 HO short block with Comp XE266HR cam, out of the box Twisted Wedge 170's, RPM air gap, 650 Quick Fuel, 89 T5, 8.8 w/3.73's. That old high milage combo actually rips pretty good. Problem with the video is I live in ND, so we've got some snow right now!
01 Ram Quad Cab
03 Grizzley 660
Old January 30th, 2012, 06:09 PM   #20
Mustang Fanatic
ALEXLOPEZ62188's Avatar
1989 Mustang LX
ALEXLOPEZ62188 is on a distinguished road
It looks like you really like the twisted wedge heads.
I wanna try them out.
Good luck with the build. I wanna see how it turns out
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/248048-fresh-306-combo-my-82-capri.html
Thread Fresh 306 combo for my 82 Capri | Forums at Modded Mustangs | BoardReader This thread Refback May 19th, 2012 10:41 PM
Threads Similar to: Fresh 306 combo for my 82 Capri
86 Mercury Capri 5.0 Joey_P 5.0 Mustangs 13 March 3rd, 2011 02:26 PM
Mercury Capri GS. 86CapriGS All Other Vehicles 1 November 9th, 2007 12:41 AM
1979 capri blackdragon 5.0 Mustangs 1 September 28th, 2007 09:38 PM
capri front end Q? bwb3 5.0 Mustangs 4 May 24th, 2007 05:57 PM
