1991 Ford Mustang GT
Aftermarket heads and ECM
I am considering getting a set of aftermarket heads now. My question is, will I have to reprogram the ECM or get it dyno tuned now?
I know I read somwhere that changing the cam will often result in needing a tune but what if I change just the heads for now, maybe the intake also, but keep the stock cam until I can afford the dyno tune also? I can finally afford a good set of heads, but don't think I can squeeze in a dyno tune also. I could be wrong, but I was thinking the heads wouldn't affect the ECM. They will simply pull in more air but as long as I am using the same cam, MAF sensor, and stock injectors the ECM will still function the same. In the future I will add a cam, larger injectors, MAF, etc. and get it tuned but for now I would like to pick up some extra horses without a lot of hassle. |
You should be fine with out a tune, you wont see every bit of hp with out a tune, but in my opinion you should upgrade your fuel pump and injectors to 24lb with a calibrated maff, with the heads
The reason i say bigger injectors, is if your pulling in more air then you need more fuel, and the stock pump, sucks
![]() DART 331ci stroker, AFR 185 heads, Trick Flow R intake, Accufab 70mm tb, 75mm pro m Maf, 30lb injectors, jba headers, 2 1/2" x pipe flowmaster super 10 mufflers, 255 fuel pump, 3:27 gears Last edited by ryanw; January 31st, 2012 at 10:34 AM. |
1988 LX
also if it aint done already, bump up the timing a few degrees. im running 21 degrees total advance, but it varies for each build
1988 lx demon 650 carb, edelbrock performer heads, crane 1.7rr, e303, no smog or a/c, 160 amp alt, 255 fuel pump, hooker shorties x-pipe & flows, stage 2 clutch, alum ds, 4.10 gears, steeda uppers, MM LCA, moroso drag springs, Strange 10-ways |
1969 Mustang Mach 1
6.824@101.61
21* total timing? That's not very much. That's less than stock.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1988 LX
oops, meant mechanical. sorry just woke up, either way, advancing should help some
Mustang Fanatic
1989 Mustang LX
You could buy the heads, the buy the MAF, Fuel pump, injectors etc....... and install everything all at once. That's what A lot of us here do
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
1992 Mustang GT
dont know yet
I'm running the entire trick flow street burner kit on my 92 with 30#hr injectors and a calibrated C&L and the only issue I have is a surge on hot starts which clears up pretty fast. That said a tune is still the optimal way to go.
Sent from my Autoguide iPhone app
______________ Mods: Paxton Novi 2000 @10psi 3.73 gears 255lph fuel pump Lucas 42# injectors Trick Flow 75mm upper intake Trick Flow 75mm throttle body Diablo "MAFia" Dyno tuned by Force Fed performance Sacramento Ca |
Dont buy c&l maffs, there no good
1992 Mustang GT
dont know yet
This one works good for me but when it gets tuned its getting a PRO-M but myself and others in my area have used them and had no issues. While I agree they are not the best I have still yet to have an issue with it.
Do you like the novi 2000 ? Thats the one i want, any neg about it ?
1992 Mustang GT
dont know yet
The novi 2000 was on my 96 gt. it wasn't a bad kit but the instructions were terrible. A lot of the parts were labeled wrong and stuff like that otherwise a great kit. When I go FI on my fox it will prob be a vortech V3 (unless they make a carb legal turbo kit by then) I like the idea of not having to tap my oil pan.
#12 | |
Oh wait..are you saying that your getting another supercharger for your foxbody ? But the novi is on your 96 right ? Okay that makes sense, i thought you were saying that you were going to remove the novi and put on the v3......
#13 | |
1992 Mustang GT
dont know yet
Threads Similar to: Aftermarket heads and ECM
| Aftermarket 4v heads | STANG34 | 99-04 | 4 | January 23rd, 2012 11:35 PM |
| Need suggestions on aftermarket heads | 1StockGT | 99-04 | 4 | December 30th, 2006 05:46 PM |
| Aftermarket Heads? | wikdsvt | 5.0 Mustangs | 7 | September 16th, 2006 11:17 PM |
| aftermarket heads | 5litercobra | 5.0 Mustangs | 0 | April 22nd, 2006 04:02 AM |
