Cant get a spark.
1st thing I checked was the coil, I got a new one it still wouldn't start. I know my car pretty well but i cant seem to figure why I its not getting spark ...where should I go from here? ....
1988 lx
9.68@142
so no spark from the coil and its turning over i assume.
-iginition switch bad -bad coil -TFI on the distrubitor bad -bad computer proly one of those.
#3 | |
1988 LX
Process of elimination. start with the easiest thing to check/replace and work your way up. thats what i had to do to mine. wound up needing a new ignition controle module
1988 lx demon 650 carb, edelbrock performer heads, crane 1.7rr, e303, no smog or a/c, 160 amp alt, 255 fuel pump, hooker shorties x-pipe & flows, stage 2 clutch, alum ds, 4.10 gears, steeda uppers, MM LCA, moroso drag springs, Strange 10-ways |
1991 Notch
Could also be a bad fuel pump relay
1988 lx
9.68@142
that has nothing to do with him not having spark.
but that is another common issue when a fox wont start. easy to check. if you turn the key and you hear the fuel pump kick on then the relay is fine.
1991 Notch
My bad I did a quick read but hey without fuel u have no bang without the spark... So unless he is for sure he does not have spark it could be that the fuel pump is not engaging due to a bad fuel pump relay...I was just throwing a bone it's quick and easy to check out bro...
1988 lx
9.68@142
no its cool. i though the same thing too, i have had that problem many times in the past. i was giving him the benifit of a doubt that he knows what the issue is and my advice is only as good as the information i am given.
Threads Similar to: Cant get a spark.
| NGK Spark Plugs 4477 - NGK Laser Iridium Spark Plugs | PanikRev41 | 2005 - 2010 | 20 | December 14th, 2011 02:45 PM |
| Nology HotWires Spark Plug Wires. More Hp More power 300% more spark..?? | 4U2C | V6 Mustangs | 4 | July 1st, 2011 04:40 PM |
| Demon Coil, IX Perormance Spark plugs,Spark Plug wires? | v6 stunna | V6 Mustangs | 15 | February 9th, 2011 01:31 AM |
| NEED HELP Please. NO SPARK AGAIN | noyz25 | 5.0 Mustangs | 9 | August 15th, 2007 06:08 PM |
| No Spark | deejay | 5.0 Mustangs | 2 | November 13th, 2006 09:31 PM |
