Foxbody Meth Injection..
Old January 31st, 2012, 11:19 AM   #1
BassMaster5000's Avatar
'90 Mustang GT
BassMaster5000 is on a distinguished road
Thinking about running meth injection in my 90 Gt when I boost it.. Just wondering if anyone has any pictures of their setup, or someone they know's set up, to just get some ideas. Thanks.
90 Gt- 331 Stroker, Forged Internals, TW Ported Heads, 30# Injectors w/ adjustable Kirban Fuel Pressure Reg, CI Custom Cam, Holley Systemax, 70mm Accufab TB, 75mm ProM MAF, BBK Fenderwell.
Dyno'd at 342/364 best E.T. is 12.8/109.
Old February 1st, 2012, 09:04 PM   #2
Duvall's Avatar
91 LX Hatch
Duvall is on a distinguished road
I use the AEM kit with medium size nozzles before and after the compressor. My tank is mounted below the drivers headlight and the pump is mounted on the canister bracket on the opposite side.
Old February 1st, 2012, 09:21 PM   #3
'90 Mustang GT
How do you like it? Any problems, or things you would change if you did it over?
Old February 2nd, 2012, 12:47 PM   #4
Duvall's Avatar
91 LX Hatch
I love it. I would not change a thing with it. Local speed shop sells it for $2.75 a gallon. I mix it 50% with water. Never had any issues.
Old February 2nd, 2012, 12:56 PM   #5
'90 Mustang GT
Do you run it all the time in your car? How long would you say a gallon lasts you?
Old February 2nd, 2012, 01:26 PM   #6
ryanw's Avatar
1991 Ford Mustang GT
If you mix it 50/50, couldnt you just buy windshield wiper fluid, isnt that a 50/50 mix ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 2nd, 2012, 01:45 PM   #7
'90 Mustang GT
I know for the windshield wiper fluid, its usually between 32-45%, but I hear you can run it.. You just have to make sure that it doesnt have Glycol?SP? in its mixture.
Old February 2nd, 2012, 01:51 PM   #8
Clueless
RAP6 is on a distinguished road
for washer fluid u need -20 and 1 or 2 bottles of HEET (the yellow bottles).
here is a list of washer fluid & methanol concentrations
http://media.photobucket.com/image/r...ethlisting.jpg
Old February 3rd, 2012, 05:54 PM   #9
'90 Mustang GT
Recent image by Cruznlife1 on Photobucket
Thanks for the link man, pretty helpful.
Old February 4th, 2012, 01:44 PM   #10
Duvall's Avatar
91 LX Hatch
When my car is running the system is on. Its run by a boost activated progressive controller. You can set when the meth starts and how much you spray.
A gallon will last me an evening cruise. Its going to depend on your set up and how often you jump on it. I always carry an extra gallon with me.
Old February 4th, 2012, 05:52 PM   #11
'90 Mustang GT
I'm definitely going to go meth injection now, thanks for the info.
Old February 4th, 2012, 08:56 PM   #12
OZ_872's Avatar
OZ_872 is on a distinguished road
I would imagine you could somehow wire the water/meth injection to a toggle switch along with the appropriate air/fuel and timing map to the same toggle switch and just flip the switch when you want to run the meth and get the extra power? I'm thinking that way if you're out of meth you can still drive around.
Old February 5th, 2012, 01:37 AM   #13
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
My system is set one a boost switch. Anything above 8psi and it comes in. I run 93 octane thou.
Old February 5th, 2012, 08:41 AM   #14
Duvall's Avatar
91 LX Hatch
As most know the meth cools the intake charge which allows you to run more timing safely. The cooler intake charge with more timing = more power.
I use quarterhorse, there is a timing map that is based from air charge temp. The higher my air charge temp goes the more it will retard the timing. I don't have to worry about running out of meth, my tune will adjust accordingly.
I also run 93 octane. My controller is set to start the injecting at 5 psi and to be at 100% flow at 10psi.
Threads Similar to: Foxbody Meth Injection..
Meth Injection HLNEZ 2005 - 2010 2 November 12th, 2011 11:47 PM
Meth Injection MustangMan00Vtech 99-04 50 April 19th, 2011 11:37 AM
meth injection kit... worrgp 99-04 19 June 27th, 2010 03:59 PM
meth injection ajm 99-04 33 April 19th, 2010 11:43 PM
Meth Injection 330CubeGt General Tech 0 June 22nd, 2009 10:43 PM
