GT40 or 351w heads
I have a set of new 351W heads just had ported and polished with 2.02 intake 1.60 exhaust. I found a 99 explorer I heard these have gt40 heads on them do you think it would be worth the swap to change to those heads? Or do you think I would lose power out of the deal? Thanks for any advice.
Crate 302, Trick Flow Intake R, 75mm MAF, bbk 75mm throttle body, bbk 76mm EGR spacer, 351 Winsor heads ported and polished by Bennet Racing, Lunati cam, 30 pd. Injectors, TKO 500, aluminum drive shaft, bbk mid length headers, bbk off road H pipe, 3:55, |
I think they have gt40p heads. They are a pain in the arse but I heard they are good heads.
http://www.stangpro.com/html/article...les/gt40p1.htm
89 GT
I'm not completely sure of this, but I think the "p" heads require different headers also because the exhaust ports are different.
...and upon reading the link, I was right. |
91 LX Notch
The exhaust port isnt different, however, the spark plug port is. The plug was repositionedn so that the spark is in the center of the combustion chamber. As a result, the plug sits at a 90 deg rather than 45ish.
http://www.sinisterstangs.com |
1987 Mustang GT 5.0 5spd
Well I would run the heads you have, and spent money on. I think the gt40p slightly better, but you already have the other heads done over.
1987 Mustang GT 5.0 5spd t-roofs, FRPP 4.10 gears, MM subframe connectors, FRPP a arms, Tokico Hp struts/shocks, alum rad, electric fan, dcc fan control unit, 6g alternator |
Threads Similar to: GT40 or 351w heads
| GT40 Heads | fastford3388 | 5.0 Mustangs | 6 | September 29th, 2008 11:44 PM |
| 351w gt40 | 01dutchGT | 99-04 | 5 | August 1st, 2007 12:58 AM |
| gt40 heads.... | fastford3388 | 5.0 Mustangs | 4 | March 9th, 2007 06:49 PM |
| gt40 heads? | acg | 5.0 Mustangs | 4 | January 25th, 2007 10:14 PM |
| gt40 p heads | 03stanger | 5.0 Mustangs | 5 | January 6th, 2007 01:14 AM |
