coolant leak
Old January 31st, 2012, 08:36 PM   #1
justsoup is on a distinguished road
coolant leak
Hey guys i just got a1990 mustang gt a couple weeks ago. I noticed that my coolant dissapears incredibly fast yet there are no physical leaks that i can see. I was thinking it may be burning up in the exhaust but im not sure. What do you guys think the problem is and how do i fix it??
Old January 31st, 2012, 08:50 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
It could be a number of thing such as, the egr spacer gasket leaking down into your intake. Or a head gasket. Or the heater core could be leaking out the a/c drain port on the fire wall or onto the passenger side floor board, so see if the carpets wet
What color is the exhaust ? Also let the car get up to temp with radiator cap off and see if you have bubbles, also change your oil and see if theres water in it.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Threads Similar to: coolant leak
Coolant leak mtucker 99-04 6 October 28th, 2011 06:30 PM
coolant leak FastGT 99-04 4 August 1st, 2011 12:19 AM
Coolant leak maxsideburn 99-04 45 December 23rd, 2010 08:06 PM
coolant leak? shadow98gt 96-98 3 May 14th, 2007 02:59 PM
Coolant leak? shan 96-98 12 April 26th, 2007 08:52 AM
