88 GT 5 Lug conversion - Rear end swap???
Old January 31st, 2012, 11:11 PM   #1
1988 Mustang GT 5.0+
Dont matter
30overchad is on a distinguished road
I have been planing on converting my drum to disc brakes. I pulled the complete rear end from a 96. Can I just bolt the rear end from the 96 in or do i have to swap the internals like i had thought originally?
I am also putting Lincoln Mark 7 spindles, callipers and rotors up front; just FYI.
Old January 31st, 2012, 11:34 PM   #2
Mustang Fanatic
ALEXLOPEZ62188's Avatar
1989 Mustang LX
ALEXLOPEZ62188 is on a distinguished road
Yea just bolt it up.
What wheels you going with?
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old February 1st, 2012, 04:40 AM   #3
wizwrath is on a distinguished road
as long as you know that the SN rear ends are wider, right?
Old February 1st, 2012, 06:08 PM   #4
Dont matter
Thanks for the replies.
I know the rear end is wider, I think it's 1.5 inches on each side of the axle if I remember correctly. I was planing on not rolling the lip and getting a set of rims with the proper offset, Cobra's or not.
I also got he brake booster with the master cylinder and proportioning valve. Do I need to add an adjustable valve to the setup or is this a "as needed" item?
Old February 1st, 2012, 06:14 PM   #5
Dont matter
What rims do you recommend? I'm open to suggestions.
Old February 1st, 2012, 06:27 PM   #6
ryanw's Avatar
1991 Ford Mustang GT
79-93 Mustang 4 to 5 Lug Conversion(SN95 disc brake conversion)
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 1st, 2012, 06:50 PM   #7
Dont matter
Sweet article ryanw, it's all there.
Thanks a million.
Old February 1st, 2012, 07:15 PM   #8
Mustang Fanatic
1989 Mustang LX
You can use s197 offset wheels with out any modifications after you install your sn95 rear axle.
I'd run anniversary wheels
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old February 3rd, 2012, 06:15 PM   #9
Troy5.0's Avatar
1988 mustang LX
Troy5.0 is on a distinguished road
for the front i used just the rotorrs from a lincoln, unless you want the calipers and spindles.
Threads Similar to: 88 GT 5 Lug conversion - Rear end swap???
easy rear 4 lug to 5 lug conversion coolcatz Classic Mustangs 0 April 17th, 2010 05:42 PM
88 GT rear disc break conversion 88BaltimoreGT 5.0 Mustangs 2 November 27th, 2008 12:58 PM
rear end conversion....... minigunner7point62 V6 Mustangs 10 September 23rd, 2008 10:51 PM
Rear Brake Conversion 90mustang 5.0 Mustangs 1 August 18th, 2008 08:28 PM
8.8 rear end conversion flattusmaximus78 V6 Mustangs 13 October 4th, 2007 09:51 PM
