April 2012 ROTM
Braking system...
I want to convert my hydroboost system on my '02 to a non hydroboost system like what is found on foxes (im assuming that there is no hydroboost on foxes correct?) What all would be involved? Do fox systems operate on vacuum? I dont intend on keeping ABS either so that should make things a little easier too.... Thanks guys
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer |
April 2012 ROTM
Bump... some one has gotta know...reps will be given lol
Mustang Fanatic
1989 Mustang LX
Do all sn95 come with hydro boost?
My suggestion would be go pull off everythin(brake booster, master cylinder, prop valves etc) off an early sn95(1994 at the latest). Yes they operate on vacuum. Should be easy to find a source
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
April 2012 ROTM
thats all I needed, thanks!
95 Mustang GT
94 was the first year for the sn95
![]() People should think about boarding up their glass house before starting a rock fight! |
1991 Ford Mustang GT
Its about time you came back, i havent seen you around other then a few random post, in a long time
Mustang Fanatic
1989 Mustang LX
He posted in a fox body forum, how do I know he knows what an SN95 chassis code is.
Now he knows 1994 is as old as he SHOULD he go.
95 Mustang GT
Whats up Ryan, been around, sadly had too many things going to work on the stang, it still sits in back of my warehouse, covered in dust, with no motor....trying to get it back on the road in the next few months.
about the post Alex you made it sound like the last year of the sn95's he should use was 94, meaning that would be the only year... guess it was in the wording...I am not real sure why anyone would want to downgrade, and especially get rid of ABS on a street car anyways.
Threads Similar to: Braking system...
| Traction Control System (TCS) and Anti-Lock Braking System | WAR-PARTY | 99-04 | 14 | May 1st, 2011 02:17 PM |
| Car died under braking? | therat1989 | 99-04 | 2 | June 16th, 2010 05:47 PM |
| braking | 95stangvert | 94-95 | 23 | September 25th, 2008 01:31 AM |
| Braking bad | whitemustang02 | The Clubhouse | 8 | March 9th, 2008 11:39 PM |
| Traction Control System (TCS) and Anti-Lock Braking System | WAR-PARTY | 99-04 | 11 | June 18th, 2007 07:56 PM |
