launching my car
Old June 8th, 2007, 10:31 AM   #1
JBIGBOOTSY's Avatar
1990 LX hatch
launching my car
I am looking to improve my 60's. What are the best ways to launch a 5sp car, side step at high rpms, feather it, any suggestions are welcome. Car has 3.55s and slicks. I have a stage control for the ignition, and the car allways lifts on the rollout and then bogs slightly before scooting on out of the hole.
Old June 8th, 2007, 11:06 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Launch at about 5000 rpm and dump the clutch. Practice, practice, practice.
Old June 8th, 2007, 11:22 AM   #3
beheivjer's Avatar
beheivjer is on a distinguished road
i just dump and go, my father laughs and slowly ive gotten better but the old man still beats me up on the track
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old June 8th, 2007, 04:24 PM   #4
ryans88gt's Avatar
I wouldn't feather your clutch unless you enjoy replacing them.
I wouldn't really side step it either. More like a "very fast" release with a very fast throttle application. Imagine you are trying to bust the tires loose on the street. I am always amazed at how much more power I can put to the ground on the track vs. the street.
Try going up in rpm by 500 rpm increments to see how your car feels launching at different engine speeds. you should be able to find an RPM that doesn't cause too much wheel spin, but doesn't result in the car bogging too much either. It'll probably be around 4500 to 5000 rpms.
Old June 8th, 2007, 04:59 PM   #5
89LX347's Avatar
89LX347 will become famous soon enough
4:56 or 4:10 gears
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old June 8th, 2007, 09:56 PM   #6
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Originally Posted by 89LX347
4:56 or 4:10 gears
That might result in more wheel spin you dont need real low gears if you got alot of HP. You just dont need the tourqe multiplying gears if you got the torque for the engine
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old June 9th, 2007, 05:06 AM   #7
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
[quote="ryans88gt"]
thats because theres like a quarter inch of nothing but rubber for like the first 60 feet of the quarter....
Old June 9th, 2007, 10:57 AM   #8
ryans88gt's Avatar
[quote="usmcsawgunner"]
That is a common misconception.
Actually it is the track prep and cleanliness and sticky tire compound, but not the rubber that improves the traction. Rubber on concrete has a static coefficient of friction of 1.0 (basically the highest possible without considering adhesive surfaces like velcro). Which means if you have a thousand pounds of weight over your rear tires you can apply 1000 pounds of force before they start to spin. On the other hand, rubber on rubber has a static coefficient of friction of 0.4-0.6 depending on temperature and type of rubber, which is actually much worse. That means with a 1000 pounds over the rear wheels you could only apply ~500 pounds of force before spinning the tires. However, the streets have dust and dirt on them, which makes the actual friction coefficient lower and the track has adhesive sticky stuff sprayed on it improving the friction coefficient to something like 1.5.
In other words it's the track prep and sticky stuff that makes it better, not the rubber.
Old June 9th, 2007, 11:41 AM   #9
Moderator
89StangGT's Avatar
SVT Cobra Mustang
89StangGT has a spectacular aura about89StangGT has a spectacular aura about
Send a message via AIM to 89StangGT
my car is the opposite. it hooks on the street but not at the track.
There's a reason Ford codenamed them the Terminator
Old June 9th, 2007, 11:52 AM   #10
What kind of slicks? How big of a burnout, do you drive through the water box? Different kinds of slicks like different burnouts and maybe you have too much water on them in the first place.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old June 9th, 2007, 12:02 PM   #11
JBIGBOOTSY's Avatar
1990 LX hatch
ET streets 26x10.5, 2nd gear burnout to about 70mph, they don't put that much water in the box. the water box isn't like driving through a puddle, they just spray it down and brush away the exess.
Old June 9th, 2007, 12:45 PM   #12
Cool, sometimes here at beech bend they dont really care on regular T&T days...I have some ET streets but havent used them yet. I was told just a quick burnot, 3-5 seconds, and they would hook all day. I dont really know though, just trying to throw out some suggestions.
[SIGPIC][/SIGPIC]
Old June 9th, 2007, 04:01 PM   #13
1993 Mustang GT
13.2 @98.54
yes...for sure i have a 75 nova (i know i know) thats a pro street and the MTs i got on it really really like a quick burnout really just to clean em off...ive never tried any other slicks but i have seen guys that say like the hoosiers and stuff need a good long burnout....dunno if thats true or not but it still makes for a good show....
Old June 10th, 2007, 10:04 AM   #14
vfast will become famous soon enough
@ advise... ..problems seems you have too much tire and not enough engine with the bog....
Old June 10th, 2007, 11:01 AM   #15
JBIGBOOTSY's Avatar
1990 LX hatch
went to T&T last night, I tried all the advise I got on here. and the best launches came from 4000 and a "controlled" fast clutch release
60'-1.7148
1/8-7.7230
mph-90.5
1000'-10.0827
1/4-12.0139
mph-116.81
Old June 10th, 2007, 11:16 AM   #16
Not bad, ALOT BETTER THAN WHAT MY PILE OF CRAP DID LAST NIGHT!!! Like people have said, you need to find what your car likes, and then keep practicing.
[SIGPIC][/SIGPIC]
Old June 10th, 2007, 11:41 AM   #17
JBIGBOOTSY's Avatar
1990 LX hatch
thanks, everyone kept telling me my ETs were slow for my mph, I think 3.73, 3.90, or 4.10s are in order.
heres the incar vid.
http://videos.streetfire.net/video/2...4900c0d624.htm
Old June 10th, 2007, 12:13 PM   #18
I got 4:10s and love them! It all depends on your setup though.
[SIGPIC][/SIGPIC]
Old June 10th, 2007, 01:21 PM   #19
1993 Mustang GT
13.2 @98.54
dude go balls out and get 4.30s i did..i havne got them here yet but i did the rpm math and in 5th gear its only running like 400 or so more rpm....so screw it and get the biggens' sure sounds cooler to have 4.30 too...haha
Old June 10th, 2007, 01:22 PM   #20
1993 Mustang GT
13.2 @98.54
ok i got the specs here....with my 25.7 inch OD tires and the t-5 trans with 4.30 gears you will be going 77 mph at 3000 rpm....so screw it get the 4.30s
Threads Similar to: launching my car
launching? blakeasaurusrex Drag 14 August 23rd, 2007 11:01 AM
Launching help!!! ByPopularDemand V6 Mustangs 12 July 14th, 2007 09:36 PM
launching 02steedagt 2005 - 2010 1 April 26th, 2007 02:49 PM
Launching thewayshemoves 99-04 20 December 14th, 2006 10:41 PM
Launching Roadhawg Drag 7 June 28th, 2006 10:16 PM
