Whats going on with my control arms?
Old February 1st, 2012, 02:16 PM   #1
88 gtu is on a distinguished road
Hi all,
I'm new to the forums and had a few questions. I have a set of tubular control arms that just aren't fitting right. Take a look at the pics. I understand that the bushings in the rearend need to be replaced and one of them is in the wrong spot. There is still something else wrong with them because they just won't line up. Any input would be a big help. Thanks, Brian
Old February 1st, 2012, 02:17 PM   #2
Old February 1st, 2012, 02:31 PM   #3
ryanw's Avatar
1991 Ford Mustang GT
Has your torque boxes been rewelded ? Did you try leaving all the bolts loose until every thing was conected also did you make sure you have the correct controll arms for your car ?
Its a little late now, but i would have put them on one at a time, its harder if you unbolt all 4 contoll arms and then try and put the new ones on.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 1st, 2012, 03:56 PM   #4
Ya i welded the battle box kit in. The car had no torque box issues it was driven by an older guy then a chick. I tried leaving all the bolts loose. I ordered them new for my car so i should have the right ones. I've had them all connected but it seems like they sit at weird angles. The stock ones were all straight. These came from blue oval which i haven't read anything good about, but theres a bunch of companys that make this same set so i really don't see how they could fuck it up.
Threads Similar to: Whats going on with my control arms?
Best rear lower control arms? need control.. Speeddemon 94-95 6 April 19th, 2010 02:55 AM
QA1 Tubular Control Arms (A-Arms) keith0s 5.0 Mustangs 3 October 19th, 2007 11:20 AM
steel control arms vs aluminum control arms Saleenwolf720 99-04 1 October 15th, 2007 01:32 PM
Upper Control Arms & Lower Control Arms LUV2XLR8 2005 - 2010 6 October 6th, 2007 11:45 AM
Steeda lower control arms (Trailing arms)? kmjsmith 2005 - 2010 6 July 4th, 2007 04:59 PM
