Current setup with nitrous? - Page 3
Old February 2nd, 2012, 11:38 AM   #41
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
I need to go to one of his classes...Probably help a bunch, lol. The guy that's tuning mine has a 90gt that had a *stock block* 351 in it. Yes, I mean STOCK BLOCK, and he was running consistent 8.0s on a 275 DR...He raced in the 275 class. He had probably 1000-1100hp in it, so I'm sure he can keep my junk from blowing with a little 150-175 shot.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old February 2nd, 2012, 11:41 AM   #42
1992 Mustang LX
13.0 @ 105
??????? Don't know.
It was built for this car.
It made 790 on nuts, on an engine dyno, and he's going to spray 2 kits on it. It flashed at 5600 in his car, so we will just have to see. Obviously it won't flash near as high in my car, which is great because I don't want it to.
those 25.5 cars are badass....Flashes that high with his power? What kinda gear does he have? Probably some stupid 4.88 or higher, lol. You'll probably have it flash closer to 3,000-4,000 lol. Not bad for street use.
Old February 2nd, 2012, 11:44 AM   #43
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I'm not sure what his gear is. That's exactly what I'm hoping for. I have the receipt for the converter, and it was abou $1800. It's $750 for a re stall, and it's free to try it, so I'll give it a shot and see what it does. If its a dog, I'll send it back.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old February 2nd, 2012, 11:50 AM   #44
1992 Mustang LX
13.0 @ 105
I bet it does just fine on spray.
Old February 2nd, 2012, 01:23 PM   #45
ryanw's Avatar
1991 Ford Mustang GT
??????? Don't know.
Those are some awesome horse power numbers................he had to have be running some flowmasters, to pull that off
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 2nd, 2012, 02:10 PM   #46
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
He actually is...lol. He loves flowmasters.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Threads Similar to: Current setup with nitrous?
Questions regarding my current setup. freefallin2000 Audio/Video 21 May 18th, 2011 11:57 PM
Current suspension setup Crisco 99-04 27 February 5th, 2010 03:06 PM
nitrous setup??? e3sean 5.0 Mustangs 4 August 2nd, 2008 12:04 AM
will these Rims fit my current setup? warrior86 Visual 1 June 13th, 2007 01:15 PM
Best Nitrous Setup? Avaric3 General Tech 12 April 30th, 2007 12:22 PM
