Help with my 88 Notch
Old February 2nd, 2012, 10:18 AM   #1
88 Notchback
orod7 is on a distinguished road
Its pretty much stock besides the GT40 upper and lower, BBK cold air intake and BBK headers. I want to go with the 170cc Twisted Wedge heads and the Trick Flow Stage 1 cam. Any comments or suggestions? What else would I need for this install parts wise? Thanks guys
Old February 2nd, 2012, 10:31 AM   #2
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Ideally, you should get these parts: New timing chain, new lifters, head gaskets, intake gaskets and you're going to need valvetrain as well.
Those heads require stud mount rockers, unless they're an older version with the pedestal mount. You will need rocker arms, pushrods (have to check for the length once everything is together) and you should get springs to match your cam even though the springs on the TFS170s are sufficient for the TFS 1.
If you're going to do a cam you should honestly get a better one...The Trick Flow stage 1 is played out and isn't ideal for those heads. Look into the Anderson N-41 camshaft. It's ~120$ more but it's very worth it. Wouldn't you like an additional 15-25hp for just 120$?
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old February 2nd, 2012, 10:32 AM   #3
1992 Mustang LX
13.0 @ 105
Also need antifreeze, two sets of oil change materials (10 quarts of whatever you use & two oil filters) and assembly lube for the camshaft...In case you didn't know.
Old February 2nd, 2012, 10:43 AM   #4
ryanw's Avatar
1991 Ford Mustang GT
I see your from california....if you 88 mustang is not a california car and you dont have mass air, then this would be the time to convert it, cuz the new cam could make the car run like crap if its speed density. California is the only place that mass air came stock in 88 every other states had speed density on there 88
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 2nd, 2012, 10:45 AM   #5
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Where in the bay?
O o
/¯/______________________
\_\
Old February 2nd, 2012, 04:42 PM   #6
fogged306's Avatar
89 GT
Sittin on the dock
Threads Similar to: Help with my 88 Notch
This is why AM is top notch: Shelbydog! The Clubhouse 4 January 24th, 2012 06:37 PM
maybe a notch SWEET2KSTANG The Clubhouse 4 March 14th, 2009 07:08 PM
89 notch 918v 5.0 Mustangs 5 March 10th, 2008 01:16 AM
