My 88 GT Build/Restoration
Old February 2nd, 2012, 04:27 PM   #1
BigStroker's Avatar
1989 Mustang GT
BigStroker is on a distinguished road
Hey fellas, I am new to this site and looking for advice on my build. I am doing a ground up restoration on a 88 Mustang GT, I am pretty pumped for this build.
So far Ive stripped the interior completely, pulled bumpers, hood and fenders to get ready for paint. I found rust around the sunroof and hatch lock area that will need to be cut out and replaced with new sheet metal. I also found some rust on the passenger door top hinge mount pillar that will need to be repaired. After that I am going to pull the motor, and smooth out all visable holes and sheet metal the front setion of the engine bay. I am also going to build a roll bar and install frame connectors and torque box reinforcment before paint. Is there anything else that I am missing that you'd suggest?
As for the interior I am going with new carpet, headliner, door panels, seats, etc. I tried to use a degreaser and interior paint an the old dash just to see how it would look and the paint didn't stick to the plastic, it bubbled up and looked terrible. What do you guys suggest I use to get this paint to stick? Maybe a primer? Or a different degreaser? Or maybe something cool I don't know about?
Looking ahead to the engine, I'd like to punch the 302 out to a 347. But as for converting it to mass air I am kinda lost, what all needs to be done? Do I need a new computer? My goal is to make this car as fast as possible but also to keep it reliable as it will be some what a DD. Any Suggestions?
Thanks for your time guys, Ive done a lot of reasearch but I am still pretty new to the foxbody world and your insight is appriciated.
Ryan
Old February 2nd, 2012, 04:53 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
mustang mass air conversion | eBay
Yes you need to change the computer for the maff convesion you can buy a kit of piece it togeather
1989-93 Mustang 5.0L A9l Computer (Pcm) for Mass Air And Manual Transmission at LRS - Free Shipping!
Ford Mustang EFI 5.0L 5.8L Mass-Air Conversion Pigtail | eBay
Plus youll need the maff meter calibrated to the size of the injector you want to use, the bracket for the maff. Im not sure if im leaving some thing out. Ive never done this, so i cant really answer any more question about it.
Id have the subframe conectors installed before you pull the engine.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 2nd, 2012, 06:31 PM   #3
BigStroker's Avatar
1989 Mustang GT
Thanks for the links and your input. Good point on doing the connectors with the engine in, never thought of that.
Old February 2nd, 2012, 08:00 PM   #4
nolife's Avatar
91GT, 88GT, 02GT
You can get a reman A9L computer (Cardone 78-4352) from most auto stores for about $90 +70 or so for a core. Even without a core, that's still cheaper than LRS. Just throwing that out there.
What's your budget?
Godspeed.
Old February 2nd, 2012, 08:51 PM   #5
BigStroker's Avatar
1989 Mustang GT
Good deal, I like options. It's an pretty much an open budget...but within reason. I always wanted to build a fox body Ford, they launch like a mofo and look sexy as hell. I am gunna take my time, gather the info I need and build it right. This forum is perfect for this project, I am learning a lot. Thanks for the info man, keep the suggestions coming guys, appreciate it.
Old February 2nd, 2012, 09:47 PM   #6
ryanw's Avatar
What's your budget?
Godspeed.
Thats cool i didnt know they can be had for so cheap, now im curious why... people on ebay and latemodelresto would charge so much for some thing that could be bought cheaper at the local auto part store
255 fuel pump,
3:27 gears
Old February 2nd, 2012, 09:53 PM   #7
ryanw's Avatar
You want the car to sit normal with the engine in it when you weld in the sub frame, if the engines out when you do it, could through some thing off
255 fuel pump,
3:27 gears
Old February 2nd, 2012, 10:02 PM   #8
Mustang Fanatic
ALEXLOPEZ62188's Avatar
1989 Mustang LX
ALEXLOPEZ62188 is on a distinguished road
Mass air conversion is actually fairly simple. Pro M sells the harness that comes with instructions. As for the PCM, you could usually find em on Craigslist.
I actually used an A9P out of a 91 GT. pulled it from a junk yard and did te 5 finger discount.
This was done to my 87.
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old February 2nd, 2012, 10:05 PM   #9
ryanw's Avatar
That the auto computer right ?
255 fuel pump,
3:27 gears
Old February 2nd, 2012, 10:09 PM   #10
fogged306's Avatar
89 GT
Yes
Old February 2nd, 2012, 10:32 PM   #11
Mustang Fanatic
1989 Mustang LX
Powertrain Control Module. Yea XD
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old February 2nd, 2012, 10:34 PM   #12
BigStroker's Avatar
1989 Mustang GT
Thanks for clearing the mass air conversion up gents, seems easy enough. I can now worry about that after I get my engine details worked out. What about painting the interior, anybody figure out a good method for painting our interior plastics that looks good?
Old February 2nd, 2012, 10:43 PM   #13
nolife's Avatar
91GT, 88GT, 02GT
I wonder the same and the reman has a warranty. I started a thread questioning that about 6 months ago. Sadly, my car is STILL sitting lifeless in the driveway where the rollback put it needing that A9L
Old February 2nd, 2012, 10:47 PM   #14
nolife's Avatar
91GT, 88GT, 02GT
If you are removing your interior already, I'd consider replacing the heater core if your are getting into the dash as well. Cheap insurance to save time later and I'm sure you'll need heat in Alberta.
Old February 2nd, 2012, 10:48 PM   #15
Mustang Fanatic
1989 Mustang LX
I have an a9p for sale. Gimme $40+ shipping
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old February 3rd, 2012, 11:09 AM   #16
BigStroker's Avatar
1989 Mustang GT
For sure, I bought the car when it was -50 and drove the car home with no heat...Heater hoses were disconnected. Needless to say the heater core will be on top of my list. Thanks again
Threads Similar to: My 88 GT Build/Restoration
Paint Restoration tommy93 General Car Care & Detailing 27 May 12th, 2011 10:24 PM
restoration chickenbot 5.0 Mustangs 3 January 16th, 2009 11:40 AM
headlight restoration kit 97fordsixer V6 Mustangs 3 May 6th, 2008 12:20 AM
interior restoration 1995v6stang Visual 3 October 24th, 2007 03:34 PM
Restoration DanHurley99 Classic Mustangs 5 March 4th, 2007 02:58 PM
