How much to replace flywheel and where to go?
Old February 2nd, 2012, 10:54 PM   #1
almcwhor is on a distinguished road
I need tips on where to go to get flywheel replaced and how much it might cost. It takes too long to remove the engine with the tools i have and i would rather spend the big mulah to have people install a seriously tough one.
Old February 2nd, 2012, 11:15 PM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Dude, you using sticks and rocks? I just recently got myself an air compressor, I've been using normal hand tools for years. If you have a two piece jack handle, you can use one half as a extention bar over a ratchet even. Anyway, if you are removing the engine to replace the flywheel, you're doing it wrong!
Old February 2nd, 2012, 11:24 PM   #3
ryanw's Avatar
1991 Ford Mustang GT
Pull the trans.
You should be able to get a fly wheel almost any where
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 2nd, 2012, 11:44 PM   #4
1995 Mustang GT
Bubba95SN is on a distinguished road
Remove transmission and the bellhousing to get to flywheel.
Old February 3rd, 2012, 12:13 AM   #5
94 GT
13.95@100
furreal302 is on a distinguished road
You're looking at 400 bucks at least to have a shop do it. That's what I would charge anyway. But like the people above me said, you don't need a whole lot of tools to do things like this. I've pulled countless engines and transmissions with a basic tool set and elbow grease. And you don't need to pull the engine to get to the flywheel.
94 Opal Frost GT ~230k
T5 swap, other mods
Old February 3rd, 2012, 08:06 AM   #6
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
Why are you replacing the flywheel for a "seriously tough one"? Is your clutch bad? Ring gear bad?
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old February 3rd, 2012, 05:13 PM   #7
e3sean's Avatar
1988 lx
9.68@142
yes what is the issue you are having to lead you to believe that you have a bad flywheel without having seen it.
also most machine shops can resurface the flywheel and male it just like new for a fraction of the cost of a new one.
if your pulling it out might as well put in a new clutch.
<font size=4><b>MILITARY CREW
Old February 13th, 2012, 11:29 PM   #8
the reason i need someone else to do it is because i do not really know how. me and my dad pulled the engine because we were replacing the oil pump and other misc. parts. and when we reconnected idk if we did it wrong or what but it cracked. i am worried that if i do it again ( maybe i did it wrong) that it will torque and break under pressure again. im not street racing this or anything either. just a moddest driver. plus the other reason for paying is that its cold as nipples outside and no garage to do it in. I really dont know but any tips would help alot. i want to do it without paying someones for my wallets sake but its just a hell of alot easier coming from a computer geek and not a car guru
Old February 13th, 2012, 11:31 PM   #9
oh and all i did to hook the engine back to the trans was reverse engineering... thats all i knew and i looked at videos and researched a TON like over the course of a week everyday on the comp for hours. and little to show for it
Old February 14th, 2012, 12:53 AM   #10
ryanw's Avatar
Youll get more info if you come back more and check the progress of your thread.
I guess your not in a hurry cuz it took you 11 days to check your own thread out.
255 fuel pump,
3:27 gears
Old February 14th, 2012, 12:28 PM   #11
Your right. I'm not in a huge hurry but still lookin for help I anyone is willing to give
Old February 14th, 2012, 03:16 PM   #12
ryanw's Avatar
I have never replaced a fly wheel before, but im guessing its straight forward, remove the bolts, and remove the pilot bearing.
Install new fly wheel torqre down bolts in a cross pattern. Ive been told its always good to use new bolts although i think most dont do it. Slide in new pilot bearing, you should be able to look up the torque specs..
Hey guys if i have this wrong, correct me, i dont want to give out wrong info.
255 fuel pump,
3:27 gears
Old February 14th, 2012, 03:24 PM   #13
94bossgt's Avatar
94 mustang gt
too slow to tell
94bossgt is on a distinguished road
ill do it for 350 you will have it back in a day if your in the allentown pa area
Old February 14th, 2012, 03:29 PM   #14
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
ryan pretty much nailed it, you'd have to press in new dowel pins to, and id go ahead and replace the bolts the old threads will be stretched and new bolts are 15 bucks, cheap insurance for something spinning that fast by your feet, and use thread locker
Old February 14th, 2012, 04:01 PM   #15
ok kewl kewl and is there a huge difference in flywheels/flexplates? i can get one for 65 bucks at napa or a "racing one" from latemodelrestoration for 170. oh btw its an automatic trans. 5.0 89 convertible if that matters. I have another question. Is there anything special to do when attack the flexplates to the transmission when connecting?
Old February 14th, 2012, 04:47 PM   #16
ryanw's Avatar
Fly wheels are manual trans and a flex plate is for a auto trans...
What trans do you have
255 fuel pump,
3:27 gears
Old February 14th, 2012, 08:33 PM   #17
Tpratt93 is on a distinguished road
You don't have to pull the engine. I actually just bought a new flywheel yesterday. 55$ from O'Reilly's. Just an OEM replacement of course. You can drop the trans, I actually just put a jack underneath it and let the jack hold it up, and pushed it back so I could get in there enough. You might run into exhaust issues, being in the way, I had to unbolt mine from the headers(shorties), after that it wasn't to bad. You'll probably need another hand when you torque it though. If not you''ll just turn the engine over.
Old February 14th, 2012, 08:37 PM   #18
And it's 75-85lbs to torque it, the flywheel anyways, I'm not sure if it's different for a flex plate. But yes, as Ryan mentions do it in a cross/star pattern so it goes down evenly. If you have a 5spd, make sure you unbolt the shifter, you can do it from underneath as well. But it's pretty self explanatory after you get under there. Other than that, make sure you get the clutch disk back in facing the correct way. (if you have a 5spd)
Old February 14th, 2012, 10:53 PM   #19
kk sorry for extending this but i am seriously confident in doing this on my own now but how in the hell did you guys unbolt the bell housing from the engine without removing the headers and/or upper intake manifold
Old February 14th, 2012, 11:02 PM   #20
brandon444's Avatar
91 Mustang LX 5.0
once you get the drive shaft out and the cross member, have a jack to hold up the end of the trans
make sure its on there good so it doesn't slip off!!!
but then slowly lower the jack slightly to tilt the whole engine and trans back, have someone else watch the engine in the bay for clearance, you should have enough to get the bolts. then you can get a long extension up there to take them out, do those before you do the other bellhousing bolts
Threads Similar to: How much to replace flywheel and where to go?
Is $600 a good price to replace clutch, tob, and flywheel? 00mustangv6 V6 Mustangs 12 August 11th, 2010 03:34 PM
4.0L to replace 3.8L???? sincityz V6 Mustangs 17 August 10th, 2010 11:21 PM
Replace it with a Mod 2006greyGT 2005 - 2010 4 March 20th, 2008 01:03 PM
5.0 to replace 3.8 big_stroke V6 Mustangs 24 January 31st, 2007 07:10 PM
427 to replace 232 94pacecarSVT V6 Mustangs 5 August 31st, 2006 06:03 PM
