88 mustang GT
unknow till strip opens
Found my problem I think
Ok I had a idle issue for a while. No high idle in the mornings either, if I drove it and came up to a light it would idle good for a little bit then start to idle like shit. I tried it all idle reset timing and still nothing. So today sprayed carb cleaner and the top intake and it reved up so I thought I was the gasket. Took it off was cleaning it to put the new gasket and there was a crack on the upper intake :/ so my ? Is will a ported and polished upper and lower intake make a difference. I'm new to the 5.0 been use to diesels all my life. Thanks
1991 mustang 5.0
If its a ported stock intake, then not really. You might gain a few horsepower but it's not worth the money. Just get a cobra or gt40 intake off Craigslist if you're looking for cheap power. I've seen gt40 intakes go for $150 on average on Craigslist. Cobras are a little more money but make literally almost the exact same power as the gt40. The cobra flows slightly more and usually go for anywhere between $200-$350 on Craigslist.
'89 LX 'Vert
10's or bust... Literally.
your intake is CRACKED........ but you want to PORT AND POLISH IT!?
I don't get the logic. ditch it in the garbage, and get a $200 typhoon intake, which will pick up more power then a ported stock intake ever would (unless you where to drop $1500 into it)
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() |
Threads Similar to: Found my problem I think
| finally found the problem | b-on-b 5.0 | 5.0 Mustangs | 5 | January 9th, 2011 01:15 AM |
| Found my problem | Blackbird1084 | 99-04 | 5 | March 6th, 2010 10:24 PM |
| I found my problem!!! | BlK2002GT | 99-04 | 10 | January 30th, 2008 12:34 PM |
| new problem found.. | whtpny | 99-04 | 14 | October 7th, 2007 04:46 PM |
| Found another problem today. | MySallyMI | 99-04 | 1 | May 2nd, 2007 09:26 PM |
