Gt40 intake install help
Old February 3rd, 2012, 01:28 PM   #1
ReefBlue1994's Avatar
1993 Mustang GT
ReefBlue1994 is on a distinguished road
I'm looking for a good write up on everything I'll need to know to install my gt40 upper and lower intake,tips,advice,or good links.thanks.
Sent from my Autoguide iPhone app
1993 Mustang GT (Reef Blue on platinum) 105k Miles, still strong.
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
NEWEST ADDITION: Eaton M90 supercharger kit
Old February 3rd, 2012, 01:59 PM   #2
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
Pull the old one off, swap everything over to the new one, you'll have to tap the gt40 intake for the act sensor that's on the number 5 runner on your stock one, you can either do it in the same place that it was on on the stocker if there's a boss there for you to do that (intakes with egr on them i believe) or you could put it some where on the upper if there's no boss for it (non egr models) tap a hole where the vacuum lines are, your not gonna need all those lines any ways.. it takes a 9/16 bit and a 3/8 tap. Ive even heard of some guys just plugging it in and zip tie it to the fuel rail
as for all the vacuum lines, make sure everything that needs a vacuum line gets one, put the pvc valve on its one vacuum line so oil doesn't get in other lines and i think you want the fpr on its own as well, not positive on that, then just plug the rest of the lines that aren't being used
Old February 3rd, 2012, 02:56 PM   #3
tyler97's Avatar
1991 gt cobra clone
tyler97 is on a distinguished road
brandon couldnt have said it better
1991 GT- Ripped torque boxes/no SFCs/306/24lb injectors/Twisted Wedge 170s/Full exhaust/Full bolt ons/X3Z computer
Buid thread http://www.moddedmustangs.com/forums...ld-thread.html
Old February 3rd, 2012, 03:24 PM   #4
1993 Mustang GT
The guy I bought it from said its already good to go in the mustang,modified,he said I may have to mess around with some hoses, but that's it,I'm looking for more of the bolt pattern, and the torque specs
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old February 3rd, 2012, 03:26 PM   #5
94 GT
13.95@100
furreal302 is on a distinguished road
20 ft lbs. tighten from the inside out.
94 Opal Frost GT ~230k
T5 swap, other mods
Old February 3rd, 2012, 05:11 PM   #6
I need a 5 lug kit
Ninety3Coupe's Avatar
1993 Mustang LX 5.0
Ninety3Coupe is on a distinguished road
I just did this by myself a month or so ago (Edelbrock Performer, but same process).
Take lots and lots of pictures. Remind yourself every few minutes to stop and take the damn picture! (It's way too easy to get going and forget) You will be very thankful you did. It isn't tough, but you are pulling a bunch of crap off and it's nice to know where it all goes back.
Also, buy some o-rings for the injectors. No sense in not replacing them while you are there. It's cheap and easy - lubed them with any light (or engine) oil first.
Make sure you have coolant (it has to be drained obviously), anti-seize (if desired on some choice bolts), gaskets, gasket maker (Black or Grey), Gaskicinch (sp?) for the gaskets and hopefully a friend and some beer.
I did it alone and I don't drink, so it was a lot tougher! lol
Good luck dude, just take your time. It's easy once you finish and you'll look back thinking so as well.
Half of Maximum Motorsports Catalog, Full Intake, Full Exhaust. Needs paint and $35,000 in mods. Car / Build Photos: http://photobucket.com/CoupePictures
Old February 3rd, 2012, 06:31 PM   #7
ryanw's Avatar
1991 Ford Mustang GT
+1^^^
Drain the coolant down.. so that when you remove the old intake, it keeps the coolant from running down into the engine..... take lots of pictures, lable ever conector and vacuum line, and put a new thermostat in while your there. And try not to break the tabs on the electrical conectors
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 3rd, 2012, 06:43 PM   #8
94 GT
13.95@100
Yeah those wires are always crispy and you will no doubt crack some of the protective loom over it. I've had problems with the front most bolts on the lower intake those like to rust and seize. So if you encounter any resistance, take your time with it. Loosen it a little bit then tighten it back down gently work the bolt out. It's a lot better than having to drill/tap a bolt hole that sits at a 45 degree angle.
T5 swap, other mods
Old February 3rd, 2012, 08:07 PM   #9
1993 Mustang GT
That sounds like so much work!haha.its quite intimidating!
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old February 3rd, 2012, 08:13 PM   #10
brandon444's Avatar
91 Mustang LX 5.0
its sounds like a lot but its really not, just take it step by step and you'll be fine
at the end youll be like damn.. that was all lol
Old February 3rd, 2012, 08:15 PM   #11
94 GT
13.95@100
just like my old gf.
T5 swap, other mods
Old February 3rd, 2012, 08:16 PM   #12
ryanw's Avatar
When it comes to working on the engine it self, the intake is about the easiest thing you can do
255 fuel pump,
3:27 gears
Old February 3rd, 2012, 08:24 PM   #13
1993 Mustang GT
I realize that but this is my first internal operation!
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old February 3rd, 2012, 08:36 PM   #14
brandon444's Avatar
91 Mustang LX 5.0
Make sure you get the mating surfaces on the head to intake spot less!! intake was first time i cracked into an engine and i was like ohhh it dont need to be perfectly clean, well i started it up and she just blew white smoke
so take your time and do it right
Old February 3rd, 2012, 08:40 PM   #15
1993 Mustang GT
I went ahead and RTVED' the head to intake gasket on,after cleaning it up,I rtved the gasket to the lower intake,and I RTVED the blue squishy gaskets to the lower intake as well,has anyone else done this?
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old February 3rd, 2012, 08:42 PM   #16
brandon444's Avatar
91 Mustang LX 5.0
i rtved the lower intake/lifter valey as well, thats the reason it took off the intake in the first place
but for i used gaskets from napa for where the intake sits on the heads
Old February 3rd, 2012, 08:50 PM   #17
94 GT
13.95@100
The only RTV I used on the intake was where the rubber lifter valley gasket met the intake gaskets. Just a dab on those corners, less is more with RTV.
T5 swap, other mods
Old February 3rd, 2012, 08:54 PM   #18
ryanw's Avatar
Oh..... are you doing the intake swap as we speak ? Wow, you dont waste any time
255 fuel pump,
3:27 gears
Old February 3rd, 2012, 08:56 PM   #19
1993 Mustang GT
No im just prepping.not sure when I'll get around to the task,trying to do as
Much prep as possible,my car is running so good right now I don't want to tear it apart.
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old February 3rd, 2012, 09:00 PM   #20
ryanw's Avatar
Did you get that plug yet for the coolant sensor ?
255 fuel pump,
3:27 gears
Threads Similar to: Gt40 intake install help
How To Install gt40 Intake And New Cam? dcam503 94-95 8 December 21st, 2011 11:36 AM
gt40 intake bennyjet846 5.0 Mustangs 1 June 23rd, 2011 05:01 PM
gt40 intake/gt40 heads black05gt 5.0 Mustangs 13 March 10th, 2011 10:47 PM
Gt40 head&intake install PhillyGT 5.0 Mustangs 3 November 22nd, 2010 05:35 PM
gt40 intake.. rauscher89lx 5.0 Mustangs 30 November 1st, 2010 12:02 AM
