Good cam for my combo?
Old February 3rd, 2012, 03:37 PM   #1
fmaster7 is on a distinguished road
Building 347 EFI with 10:1 compression. 2.05 / 1.60 valves, 1.72 cobra rockers
60cc chambers.
My problem is, exhaust valve hits the pistons with the cam I have in my motor.
I would like a cam with over .500 lift and lower duration.
Cam I have now:
******* 110 deg center,
******* 224 in,
******* 232, ex,
******* 0.592" intake (effective lift w/ 1.70:1 rockers),
******* 0.602" exhaust (effective lift w/ 1.70:1 rockers),
******* 114 deg sep,
******* 0 overlap
Old February 3rd, 2012, 03:40 PM   #2
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Wow...you're going to kill that 347. What pistons are in it? IMO it's pointless at this point to have spent money on stroker stuff, heads, ect....and then limit yourself like that. Pistons can be notched in the block for relatively cheap.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old February 3rd, 2012, 03:45 PM   #3
Well I already have the heads on. They are SRP 4.030 with valve reliefs.
Old February 3rd, 2012, 03:53 PM   #4
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
are you sure the cam is installed correctly? Is it straight up? With a 2.05 intake valves on a stock style piston, there's a chance that no cam will work.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Threads Similar to: Good cam for my combo?
Good combo h/c/i for 347 block? nstys2k General Tech 0 April 23rd, 2011 09:11 PM
Is this 302 combo good for 11s? Cloud Nine 5.0 Mustangs 31 January 29th, 2011 02:29 PM
a good combo for 5.8 EFI? rasalibre 5.0 Mustangs 16 September 25th, 2009 07:57 PM
Piecing a good combo. suggestions? Frankenstang 5.0 Mustangs 9 August 28th, 2008 09:15 AM
good exhaust combo ddashtrois 99-04 15 October 1st, 2007 07:16 PM
