Engine for the 83
Holley 600 carb
torqer II intake cam Lunati 61012 - Lunati Hydraulic Roller Tappet Camshafts - Overview - SummitRacing.com twisted wedge 170s on a stock 302 rebuild. 8.8 rear with 3.55s world class T5 tubular rear control arms full msd ingnition electric fuel pump Look decent? Im trying to get close to 400 would I need to stroke it? Carb to small? Last edited by Ohsplat; February 3rd, 2012 at 10:22 PM. Reason: forgot something |
1991 Ford Mustang GT
What is this for.....i thought you finished the 83
1991 Mustang LX 5.0
Almost 400ish crank yes, wheel no
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Nah the 87 is the vert. I am not starting back on the 83.
The normal 83 was 185 at the crank i believe and the 93 was 205. 400 would be a nice upgrade =) |
1991 Mustang LX 5.0
Just food for thought info. In 93 they changed how they rated the motor, so it really isn't any different than 89-92 except for a few tiny changes that didn't really matter as I've read it.
#6 | |
Isnt 87 and 88 the same hp to ? I know there not mass air but i still thought they put out the same
1991 Mustang LX 5.0
Theoretically, they say they were just a tad quicker due to not having the restriction of the mass air meter, but who knows
89 GT
What kind of exhaust? I'm not too sure you're gonna hit 400 at the fly with that combo.
#9 | |
From what I read on wiki the 90-90 was 20hp less. 8-89 was 225 and 90-93 was 205. The exhaust is mac headers with full flowmasters. |
1992 Mustang LX
13.0 @ 105
Cam and heads seem like a decent match. I'd say go with a 650 Holley or a Pro-Systems carb. Also, I wouldn't use the torqer intake either...On my local forum I can find used Victor Jr. intakes for 100$... If the motor is an original 83 piece, I'm pretty sure you don't have valve reliefs in those pistons. You'll need to flycut for that head/cam combo to make it work. Realistically, I can see 365hp with the parts listed. If you have good exhaust (need to know the diameter) and a Victor Jr. ~390hp is more doable.
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
1992 Mustang LX
13.0 @ 105
How big are the headers? Ditch the Flows too..They're very restrictive. I'm getting rid of mine for that reason.
Threads Similar to: Engine for the 83
| 03 crown victoria engine vs. 2003 mustang gt engine?? Which tko 500? | 98 Stanga Banga | 99-04 | 8 | September 20th, 2010 08:25 PM |
| 2005 V6 engine swap to 2002 saleen engine | MCLARK | V6 Mustangs | 7 | May 14th, 2010 06:02 PM |
| 2005 V6 engine swap to 2002 saleen engine help? | MCLARK | 2005 - 2010 | 7 | January 11th, 2010 09:27 AM |
| Engine install: Life engine up, or drop engine? | trill gear head | 2005 - 2010 | 14 | October 26th, 2009 01:17 AM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 05:09 PM |
