1989 Ford Mustang lx
stock pushrods in performance engine
I have an 89 mustang lx with a 351 windsor engine. It is basically as built as i can make it without doing forced inducion and an even larger cam. I have a comp cam (.512 lift) in it right now, and bent a pushrod. can i use an old stock pushrod i have in this engine being built as it is? or do i need some type of performance rods?
1989 mustang lx -351 windsor -bored .040 -Edelbrock Aluminum performer RPM intake -Holley 750 double pumper -780 jet kit -512 lift comp cam -racing C6 tranny/reverse valve body -all forged internals/11:1 too many more to list
1991 Ford Mustang GT
You need to measure it and replace with the same size ( thats if the pushrods in there already are the correct size to begin with)
if they are the exact same length and diameter, then it will deffinately work?
Did you diagnose why it got bent in the first place ? You might need to change them all out to hardened push rods.
Sorry bro im no valve train expert, so im going to have to leave the rest to some who knows more about valve train components
1991 Mustang LX 5.0
I would certainly NOT use a stock pushrod. Aftermarket are hardened.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Thats fine. The rod bent from a rocker coming loose. Do you know if there is any way to tell a difference from hardened pushrods from stock?
Threads Similar to: stock pushrods in performance engine
| stock pushrods needed | goose-it87 | 5.0 Mustangs | 0 | November 2nd, 2011 09:22 AM |
| 96-98 gt stock performance? | mustang98v6 | 96-98 | 21 | September 17th, 2010 10:45 PM |
| new stock 5.0 what performance part should i add first? | 5.0 lover | 5.0 Mustangs | 56 | August 28th, 2010 12:44 AM |
| Too Much Lift For Stock Pushrods | LOC289 | Classic Mustangs | 3 | August 14th, 2008 08:25 PM |
| performance cam/stock heads? | 1990CA50 | 5.0 Mustangs | 17 | February 6th, 2007 01:02 PM |
