I/E valves?
Well I just got a set of Pro Topline 180cc heads for a good deal. I am looking for intake and exhaust valves now. I was going to get the cheap RHS head kits and just use the valves from those kits since their basically the same material as other valves sold anyhow. I could get the whole kit for 132 to assemble a whole cylinder head.
The problem is I'm fairly sure the springs aren't for hyd roller cams. The guide plates are wrong because their not meant for offset intake valves. And the valves stems are .342 and I am fairly sure my valve guides are .341.
It would be nice if they would work though since the the price is cheap enough that even if I could only use the valves it would be worth the buy.
Anyways, my problem is that I have to choose a valve length and they are all different sizes and to make things more confusing the exhaust valves are completely different sizes than the intake valves, none of them match. For instance, I can't get 4.960 intake and exhaust valves. I could only get the intake valves but the exhaust valves are a different size. I expected them to be the same length.
Which valves would you recommend? What length and tip size would you go with?
