MAF Conversion - Forums at Modded Mustangs
post #1 of 9 Old February 5th, 2012, 12:48 PM Thread Starter
Troy5.0's Avatar
MAF Conversion
I'm building up my motor and putting 30lbs injectors, now for the maf conversion what do i need besides the Mass airflow meter/sensor?
THANKS
Troy5.0 is offline
post #2 of 9 Old February 5th, 2012, 01:18 PM
Mustang Fanatic
Alexlopez's Avatar
You need the harness, computer, and the tubes for the MAF meter. Might as well get a nice cold air intake or maybe a power pipe.
Harness:
1986-88 Mustang 5.0L Mass Air Conversion Wiring Harness by Pro-M at LRS - Free Shipping!
2003 Mustang SVT Cobra:
Borla Stingers
Pypes X Pipe
H&R Race Springs
JLT RAI
Alexlopez is offline
post #3 of 9 Old February 5th, 2012, 01:45 PM Thread Starter
Troy5.0's Avatar
i dont need to swap the whole harness right? just add that harness from late model restoration?
Troy5.0 is offline
post #4 of 9 Old February 5th, 2012, 03:07 PM
Mustang Fanatic
Alexlopez's Avatar
Yup. Read the instruction thoroughly, and it'll take you about 30-45min to do it.
Borla Stingers
Pypes X Pipe
H&R Race Springs
JLT RAI
post #5 of 9 Old February 5th, 2012, 11:31 PM
She's my Unicorn!
very easy to do
BlackBetty88GT is offline
post #6 of 9 Old February 6th, 2012, 01:47 PM
Mustang Mass Air Conversion StangNet
I used this. It worked well.
You may need to get some EEC4 computer pins if you follow this link.
I hear without doing all these steps, you'll have check engine codes, but I can't verify that.
chrisbmx is offline
post #7 of 9 Old February 6th, 2012, 08:32 PM Thread Starter
Troy5.0's Avatar
when i do build the motor what will it run good if i keep speed density or is this a must have conversion?
Troy5.0 is offline
post #8 of 9 Old February 6th, 2012, 08:56 PM
skeletonpsycho's Avatar
acually speed density is the way to go you just have to have it tuned by a pro so no it is not a must have but alot of people do it to save money on a tune and they put a hot driveway tune on it
just your average all motor pump gas 10sec street car
owner operator@RACEWires-High Performance Automotive Wiring
skeletonpsycho is offline
post #9 of 9 Old February 7th, 2012, 12:54 AM
ryanw's Avatar
Whats better about speed desity ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
ryanw is offline
Human Verification
