1992 Lx hatch
Engine troubles?
my mustang today was running great, took for test drive was driving fine, stopped turned around and car backfired then turned around to go home and backfired more and loss power any more than 1/8 throttle and more popping reved when in driveway blew a flame..
what could be my problem? also, my thermostat housing has a hole in the top for a sensor, i have the plugt on the wireing harness but am wondering what sensor goes there? |
1991 Ford Mustang GT
Nothing goes in the thermostat housing, i believe you have an after market housing, if you ever install an electric fan, you can plug a thermostat for the fan control there.
And about your problem ,Check your fuel pressure
![]() DART 331ci stroker, AFR 185 heads, Trick Flow R intake, Accufab 70mm tb, 75mm pro m Maf, 30lb injectors, jba headers, 2 1/2" x pipe flowmaster super 10 mufflers, 255 fuel pump, 3:27 gears Last edited by ryanw; February 6th, 2012 at 12:21 AM. |
2001 Mustang GT
9.30 @ 77mph-1/8th mile 2.2 60'
![]() iTrader: 3 reviews
Timing off?
01 GT. 5spd , 03-04 cobra clutch, on its 2nd 4.6l motor 2nd tr3650 too,JLT CAI,UPR o/r x, magnapack catback, predator tuned, H&R ss 10.5" bullitts w/ nt555r DR's
1992 Lx hatch
timeing is on and there is fuel presusre,
heres where it gets intresting, i put key in ignition to watch my gauge for fuel pressure and i see it, then go to crank over and she cranks once and . Dead. could this be my altonatir? car wont rev, and idles barly.. |
Before we rules out fuel pressure.... as being the cause or part of the issue...
What did the gauge read, you should get about 39 psi with vacuum line disconcted from the fuel pressure reg.
1992 Lx hatch
im getting 40 psi on my gauge at the fuel rail... and same as when its running
So it cranks once and then acts ad if the batterys dead, and wont crank any more ?
1992 Lx hatch
yes, then i charged the battery with my charger and it started, after about ten min it wanted to die, surging from 200 rpm to 1100 rpm about around there, then it wouldent start after that, just had the altenator checked at autozone it IS good,
1988 mustang LX
iac valve maybe
2001 Mustang GT
Can a starter be weak?.. I would test the starter too
2001 Mustang GT
Kinda sounds like a maf sensor issue? Try cleaning it with maf cleaner from parts store.
1992 Lx hatch
Starter is actually new, most everything is from the build, and a dirty maf sensor? what would this do if dirty?
1988 mustang LX
i had trouble with the idle going from 200 to 1200 rpm i cleaned the IAC valve it worked for abit then i just ended up buying a new one and i havent had the problem since. but i didnt have the back fire problem that could be a faulty O2 sensor.
2001 Mustang GT
Run like shit. Similar to what you experiencing.
1992 Lx hatch
so dirty maf or dirty IAC ile check them bolth in the morning deffinatly,
2001 Mustang GT
Good deal. Let us know.
2001 Mustang GT
You may have to have a safety torch bit to get maf sensor off. Not sure though. Mine does but it's an 01
1992 Lx hatch
no i had it off once befor cuz i bought the maf used on cl,
1991 Mustang LX 5.0
Dude, if you have a voltage issue, then it's nothing with your sensors. Check all your power connections and ground connections. If everything looks good there, then take your alternator to a different place to get checked. Sometimes the kids at autozone don't know what they are doing.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
2001 Mustang GT
Checked on test stand or in car through the battery with their batt,starter,and alt tester?
Threads Similar to: Engine troubles?
| Engine Troubles... 97 GT | I am you | 96-98 | 13 | August 3rd, 2011 12:10 AM |
| need help fan troubles | 93 notch | 2.3 Mustangs | 2 | July 11th, 2011 01:23 PM |
| Ahhh troubles, troubles. | 02trueblueGT | 99-04 | 1 | August 20th, 2010 06:49 PM |
| still have troubles | krispy | V6 Mustangs | 2 | July 14th, 2008 02:58 PM |
| having some troubles | Blk01ponyGT | 99-04 | 4 | February 14th, 2008 08:04 AM |
