valve spring install height for AFR 185 part# 1422
LinkBack (1) Thread Tools
Old February 6th, 2012, 02:05 PM   1 links from elsewhere to this Post. Click to view. #1
ryanw's Avatar
1991 Ford Mustang GT
Does any one know the valve spring install height on a afr 185 cylinder head part # 1422 ?
Ive searched over on another forum, and ive read 1.8 & 1.82.
I need to see written literature that is fact and not guesses.
The reason for this is id like to have the matching springs for my custom cam. The springs i have now , i believe are the ones that cam with the heads. I emailed comp cams and gave them my cam info.....they said they needed the install height for my heads... so i emailed afr, and they have not gotton back to me. Ive tried looking at afr web page but either that info is not there or i just dont understand what im looking at...lol
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 6th, 2012, 03:20 PM   #2
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
I'm pretty sure they are 1.80. These are the springs that come on the 1422 head.
http://www.summitracing.com/parts/AF...n/?prefilter=1
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old February 6th, 2012, 03:24 PM   #3
ryanw's Avatar
Are you going by memory or do you have some thing written in stone ? Are all Afr heads , have the same install height or do the vary from model # ? I wasnt sure thats why i listed the part number..
255 fuel pump,
3:27 gears
Old February 6th, 2012, 04:21 PM   #4
Click on the Summit link in my above thread. According to the AFR website that is the spring that comes on the 1422 head. Summit link lists installed height at 1.80.
01 Ram Quad Cab
03 Grizzley 660
Old February 6th, 2012, 04:57 PM   #5
ryanw's Avatar
Thanks.
I would like to every ones opinion.
Do you think getting match springs would be a good idea or am i just going to through away money. My valve spring that came from AFR state that they can take a .600 lift and my cam only has .....well here is my cam specs
Here is a copy of the spec card: CAM
SERIAL # M 8410-08 SPEC CARD # 13557708 SPEC CARD INQUIRY BY SERIAL #
PART # 35-000-8 FW FORD 351W/302HO HR/SR
CORE C35-8P FW FORD 302 H.O AUSTEMPERED Special Grind
GRIND # FW 3016F/ 3035F HR13
DURATION @ .050 INTAKE 230 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 224 INTAKE 1.60
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3600 EXHAUST 1.60
VALVE LIFT INTAKE .576 LOBE LIFT EXHAUST .3530
VALVE LIFT EXHAUST .565 LOBE SEPARATION 113.0
DURATION .006 INTAKE C/L 111.0
TAPPET LIFT INTAKE 280 CAM ADVANCE 2
TAPPET LIFT EXHAUST 276 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 4 JOURNAL DIAMETER STD 2.036
VALVE OPEN EXHAUST 47 RECOMMEND VALVE SPRINGS
VALVE CLOSED INTAKE 46 DEPARTMENT R
VALVE CLOSED EXHAUST 3-
255 fuel pump,
3:27 gears
Old February 6th, 2012, 05:10 PM   #6
I would get ahold of Comp & see what spring they recommond, then check the seat pressure @ installed height(1.80) and at open pressure(usually 1.20-1.23) with their recommonded spring then look up your springs and compare.
01 Ram Quad Cab
03 Grizzley 660
Old February 6th, 2012, 08:35 PM   #7
Proud American
MustangMatt96GT's Avatar
Always match a set of springs to the cam...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old February 6th, 2012, 10:24 PM   #8
ryanw's Avatar
Oh i agree, i just want to make sure that the spings they want me to buy arnt going to be same as what i already have from afr. When i get the spring specs ill post them up, and we all your guys help, we can figure out if i need them or not. Thanks
255 fuel pump,
3:27 gears
Old February 6th, 2012, 10:42 PM   #9
FastStang91Lx's Avatar
1991 Mustang LX 5.0
I had my springs checked against the cam specs when I had my heads off. They are the springs that came with my heads (dual spring good for 600 lift) and I have the stage 2 cam. They were right within spec.... coincidence???????
Old February 6th, 2012, 10:45 PM   #10
ryanw's Avatar
Lol.
255 fuel pump,
3:27 gears
Old February 7th, 2012, 02:37 PM   #11
ryanw's Avatar
This is what comp cams recomened
Part# 987-16 dual coil springs
StreetSideAuto - Auto Parts, Car Parts, Truck Accessories, Truck Parts, Car Accessories and Performance Parts
And retainers part # 740-16
255 fuel pump,
3:27 gears
Old February 7th, 2012, 03:09 PM   #12
Well according to the Summit web site the Comp 987 has 121lbs seat pressure @ 1.80 installed height, 343lbs open @ 1.20 and 370lbs spring rate. The spring that come on the 1422 AFR have 135 seat pressue @ 1.80 installed height and 340lbs open pressure @ 1.23 with a 360 lbs spring rate.
I would just use the ones you have.
01 Ram Quad Cab
03 Grizzley 660
Old February 7th, 2012, 04:42 PM   #13
ryanw's Avatar
Good to know, i just ajusted my roller rockers and im drawing a blank if i a had dual or single springs in there but it looks like the afr springs you posted were single, so im guessing thats what i have.
Whats the difference between single and dual spring, whats the point of them ?
I also want to make sure i ajusted my rr right.
What i did was rotate the crank clock wise, as my exhaust valve starts to open, i stoped, and lossened the nut, waited less then a min to let the lifter rise back up, then i twisted the push rod until a felt a little drag, i then turned the nut one half turn ( 180 degrees) locked the nut down.
I then turned the crank, and watch the intake valve open and just as the intake valve was going to close, i ajusted the exhaust valve, the same way...
Does this sound right ?
Also depending on where i look it up some say to go either 1/4-3/4 past zero lash but i saw a you tube video that said to go one full turn, which is it, or are they both correct ?
Thank horsepowerjunki, i would have already added to your reputation but this tab im on wont let me, ill do it when i get home bro.
255 fuel pump,
3:27 gears
Old February 7th, 2012, 09:44 PM   #14
1991 Mustang LX 5.0
I'm a half turn kind of guy, and yes, your springs are close enough to be perfect.
Old February 7th, 2012, 10:14 PM   #15
ryanw's Avatar
Okay, cool..... but the process in which i ajusted the rr.....is that correct ?
255 fuel pump,
3:27 gears
Old February 7th, 2012, 10:30 PM   #16
1991 Mustang LX 5.0
Yeah, as long as you weren't in the overlap part of cam. Intake and exhaust can be open at the same time. Adjust your intake on end of compression stroke/start of power stroke, and your exhaust on compression stroke if you are uncertain.
Old February 7th, 2012, 11:27 PM   #17
ryanw's Avatar
Hmmmm im a little uncertain how to do that....
Also i was wondering are there two cylinders that are lined up at the same time ? What i mean by that is if im ajusting the intake valve on the number 1 cylinder ,is there another cylinders, intake valve that can be ajusted at the same time with out have to move the crank ? If so can you list the cylinders that are lined up togeather ?
255 fuel pump,
3:27 gears
Old February 8th, 2012, 10:38 AM   #18
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
I was too lazy to type. read post # 2 and think "valve float"
dual vs single valve springs - Chevelle Tech
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/249037-valve-spring-install-height-afr-185-part-1422-a.html
Thread Install height for Comp springs? | Forums at Modded Mustangs | BoardReader This thread Refback March 27th, 2012 06:52 PM
Threads Similar to: valve spring install height for AFR 185 part# 1422
Install height for Comp springs? 40thAnnivGT 99-04 6 March 23rd, 2011 09:32 PM
Valve spring help sterlingboy V6 Mustangs 4 January 22nd, 2011 02:19 PM
Valve spring help sterlingboy V6 Mustangs 3 January 21st, 2011 12:17 PM
changed ride height with k member install S281 99-04 11 December 14th, 2010 06:41 PM
Valve Spring Kit?? BoostHard1210 99-04 11 February 12th, 2009 09:19 AM
