Cam or gears?
Old February 6th, 2012, 03:28 PM   #1
1988 5.0 mustang fox body
rocha5.0 is on a distinguished road
Cam or gears?
Im not sure what to get first a cam shaft or 3.73 gears or anything also that would be better
I don't have much right now but my goal is to be a fast daily driver so when it comes to races I'll win, here's what I have.
Bbk: 75mm tb, fuel pump, off road x pipe, cold air intake,
M.A.C:pulleys, shorty headers
K&N oil filter
ford racing: spark plug wires, header gasket
GT40: heads, intake
NGK: spark plugs
Flow masters super 44 dumps no cats
MSD small coil
Sent from my Autoguide iPhone app
Old February 6th, 2012, 03:31 PM   #2
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Depends on if you have an auto or stickshift...
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old February 6th, 2012, 03:39 PM   #3
1992 Mustang LX
13.0 @ 105
If it's an Auto, gears hands down. If it's a stick, you can get away with the cam and stock 3:08 gears but you'd need to upgrade down the road to feel the effects...I would just do gears and the cam together since gears are all of 200$.
Old February 6th, 2012, 03:39 PM   #4
It's auto right now but going to do the 5speed conversion
Old February 6th, 2012, 03:40 PM   #5
1992 Mustang LX
13.0 @ 105
And please...Don't get a b-cam or an e-cam...They drive like shit and their specs aren't up to date. Get the Anderson N41 cam for those heads.
Old February 6th, 2012, 03:41 PM   #6
1992 Mustang LX
13.0 @ 105
Good..Autos are dogs without a nice stall converter.
I suggest gears and then the cam because you will feel the difference in gear ratios much more than a cam swap alone.
Old February 6th, 2012, 03:44 PM   #7
What exactly do gears do and do I need a tuner with it?
Old February 6th, 2012, 03:50 PM   #8
1992 Mustang LX
13.0 @ 105
We don't have newer mustangs so we do not need a tune. We do, however, need a new speedo gear so your speedometer is correct.
Let's put it this way..I explain gears this way any time someone asks what they do.
Imagine you're riding a mountain bike and you had to start in 3rd gear every time..think of that as your 3:08/3:27 (stock, depending on what options your car has) gears. No matter what you have to lug your pedal speed up in 3rd gear from a start to get to speed.
Now, say you're riding that same mountain bike and you start in 1st gear. That is the equivalent of putting 3:73s or 4:10s in your car. You start moving easier and you can accelerate faster, but you have to shift more frequently and you pedal fast even easier.
Does that explain gears a bit?
Old February 6th, 2012, 04:25 PM   #9
Yeah the car picks up more speed, thanks what gears should I get
Old February 6th, 2012, 04:26 PM   #10
1992 Mustang LX
13.0 @ 105
The gears will make your car accelerate harder and it will also turn more RPMs in general. What's your intended use for the car? Purely street? Personally, I would go with 4:10s.
Old February 6th, 2012, 04:34 PM   #11
selbyvince's Avatar
1991 ford mustang lx 5.0
12.1@114
selbyvince is on a distinguished road
id do gears first, and i 2nd 4.10s unless you do alot of highway driving. i have 4.10s in my car and love it, but my car is not a daily (unless i want it to be), doing 70 on the highway it throws about 2500 rpms, and with longs tube headers, no cats, and straight through mufflers, its loud and annoying depending on how long i drive it. and i get 10mpg everywhere no matter in city or highway. but other then that, i love my 4.10s.. 3.73 wouldnt be bad either.. all depends on how u use your car.
91 5.0 lx
Old February 6th, 2012, 04:34 PM   #12
It's my daily driver but want it able to be fast
Old February 6th, 2012, 04:39 PM   #13
1992 Mustang LX
13.0 @ 105
I'd say get the 3:73s. I have them and I'm happy but I want more so I'm getting 4:10s.
Old February 6th, 2012, 04:48 PM   #14
What 1/4 mile time would you think I get if I had the gears?
Old February 6th, 2012, 04:54 PM   #15
1992 Mustang LX
13.0 @ 105
If you had 3:73s, the cam I suggested, slicks and a good driver I would take a good guess of 12.5-12.6 @108 MPH.
Old February 6th, 2012, 05:05 PM   #16
If I get the gears I need the kit too?
Old February 6th, 2012, 05:28 PM   #17
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I'm assuming you're talking about an install kit? Yes, you'll still need it as the gears will just be the ring and pinion gears.
I would certainly do gears before a cam.
I have 3.73s, and I'm glad I didn't go 4.10s. Honestly, for the way I use the car, I would've been happier with 3.55s, but I certainly won't complain about how hard it pulls in 2nd/3rd gear.
O o
/¯/______________________
\_\
Old February 6th, 2012, 05:38 PM   #18
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Gears fo sho
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old February 6th, 2012, 07:39 PM   #19
What should over ford racing or motive performance
Old February 6th, 2012, 07:43 PM   #20
I need a 5 lug kit
Ninety3Coupe's Avatar
1993 Mustang LX 5.0
Ninety3Coupe is on a distinguished road
Keep in mind, due to you mentioning budget, that you are gonna want to pay someone to do either job here - cam or gears. With gears you should have an expert install them for sure.
There are many of us that have spent our share of time with a wrench in our hand that will not attempt a gear swap on their own. Do it wrong and at best you will be annoyed by the noise it'll make. At worst you will put it in drive followed by a very loud noise and then you aren't going anywhere.
Not that you can't accomplish this task, but I would say having someone that has done it before (like a hundred times) is almost a requirement.
The cam would be something to consider farming out as well, however I know a lot more folks that have done a cam swap than gears and would lend me a hand, and I bet you do to. It's not a simple task, for certain.
As far as which one to do, you want to do both, obviously. The gears would probably be the way I'd lean, but then again I have a friend that owns a Jeep / Off-Road shop (installation only) and he does these in his sleep! lol
Good luck (and go with Ford Racing 3.73's IMHO)!
Half of Maximum Motorsports Catalog, Full Intake, Full Exhaust. Needs paint and $35,000 in mods. Car / Build Photos: http://photobucket.com/CoupePictures
Threads Similar to: Cam or gears?
Possibly Getting New Gears...THIS IS NOT ANOHER ''WHAT GEARS SHOULD I GET THREAD"! BC03 99-04 84 September 10th, 2011 05:44 PM
speedo gears for 4.30 gears bcinthearmy 94-95 2 April 23rd, 2009 12:02 AM
3.73 gears or 4.10 gears? I need to get away from the 3.31's 07torchgt 2005 - 2010 91 November 11th, 2007 12:25 AM
