going to coilovers
Old February 6th, 2012, 06:49 PM   #1
shamrock81887's Avatar
1993 mustang gt
stock
shamrock81887 is on a distinguished road
going to coilovers
Mustang Eibach Springs Pro Street Coil-Over Shocks - 3510.710 | eBay
I would like to buy these but what other stuff do i need to get these on my car? I have never messed with suspension stuff before.
Old February 6th, 2012, 07:13 PM   #2
1993 mustang gt
stock
Im gonna order them once i get a debit card for my bank account because they dont accept echecks so i gotta wait . I just thought somebody might be able to point me in the right direction as far as parts i need to make the conversion.
Old February 6th, 2012, 07:32 PM   #3
I need a 5 lug kit
Ninety3Coupe's Avatar
1993 Mustang LX 5.0
Ninety3Coupe is on a distinguished road
I looked into doing that kit (same eBay seller in fact!) and then ultimately decided to go with a Maximum Motorsports setup. Too many folks told me that a Sports Box would make the car handle far, far better and would be priced similarly. Holy guacamole were they right!
I still have the Panhard Bar to install, but everything else is in and I couldn't be happier. It's a great kit, and I highly recommend getting the adjustable lower control arms with it. I had sub-frame connectors already so my parts shop replaced those with the A-LCA's (for a nominal fee, of course). I sometimes wish it were a pinch more firm, but every time I take a freeway on-ramp or the like I am AMAZED at how well the car is absolutely screwed to the planet. And it is comfy as as be driving around town. Perfect.
It all depends on what you want the kit for, but handling wise, you cannot go wrong with MM. Trust me.
Good luck sir in whatever path you choose!
FYI, I got this kit:
1990-93 Mustang hardtop Sport Box [SB-2] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
Half of Maximum Motorsports Catalog, Full Intake, Full Exhaust. Needs paint and $35,000 in mods. Car / Build Photos: http://photobucket.com/CoupePictures
Old February 6th, 2012, 08:01 PM   #4
1993 mustang gt
stock
I want the adjustable height. I want to lower it, but not too much or too litte. Plus these sound like they should have excelent handling over stock.
Old February 6th, 2012, 08:04 PM   #5
1993 mustang gt
stock
So do i need cc plates or a bumpsteer kit with this?
Old February 6th, 2012, 08:05 PM   #6
skeletonpsycho's Avatar
1987 mustang GT
10.92@122
skeletonpsycho is on a distinguished road
all the info you need is right here MM hands down
http://www.youtube.com/watch?v=gQ7g9ystpiU 347 all motor wawa pump gas driven everywhere
Old February 6th, 2012, 08:15 PM   #7
1993 mustang gt
stock
The kit looks good but i am trying to lower it as much as possible when i take it to car shows, and raise it back up when im racin around the country in it
Old February 6th, 2012, 08:15 PM   #8
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
You don't really need the bump steer kit. You will need something other than the stock shock mounts for the front. If you try to run coil overs w the stock mounts, you'll end up pushing the idolaters through the mount plates.
I am running a max Motorsport c/o kit w their cc plates. Love it. I am running 275 lb springs in the front and their road and track springs in the back. They are a bit firm but the car handles its nuts off and I'm not finished yet. I still need upper control arms (found a nice set that bmr makes), pan-hard bar, battle boxes and welded unibody seams.
What you need to do is to peep a cat named jazzer on here and pick his brain.
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old February 6th, 2012, 08:19 PM   #9
1993 mustang gt
stock
So ill need to fab my own mounts?
Old February 6th, 2012, 08:19 PM   #10
I need a 5 lug kit
1993 Mustang LX 5.0
Well sir, if that's what you want then that is what you shall have.
CC plates should do you just fine. According to MM, which I tend to believe, bumpsteer kits are needed only at a certain point and a lot of what you hear is fallacy. As long as the tie rod and the lower a arm move with - and are parallel to one another (to a certain extent) - then you should be fine. If you intend on dumping it, then yes, get the bumpsteer kit.
I wish you luck and don't forget to post pics when it is installed!
Threads Similar to: going to coilovers
Coilovers? clodingos97 2011+ 7 July 6th, 2011 05:32 PM
coilovers in DickH 99-04 44 June 22nd, 2011 01:26 PM
coilovers zigbigadoru 96-98 15 July 16th, 2009 05:51 PM
hmm coilovers in but... njstang 99-04 6 April 27th, 2009 08:33 PM
coilovers. patwrecked General Tech 2 April 17th, 2007 09:07 PM
