car running off batt
Old February 6th, 2012, 08:04 PM   #1
1992 Lx hatch
duvaltom is on a distinguished road
my car seams to be running off just the battery not the altonator, took the altonator off and had tested, it IS good, battery IS new just bought today i was using old junk i had but laying around so i bought a New one!
my battery gauge is reading about 9 amps , any hints?
is there some sort of fuse in the charging line?
Old February 6th, 2012, 08:07 PM   #2
skeletonpsycho's Avatar
1987 mustang GT
10.92@122
skeletonpsycho is on a distinguished road
whats your reading at the alt and battery not the guage
http://www.youtube.com/watch?v=gQ7g9ystpiU 347 all motor wawa pump gas driven everywhere
Old February 6th, 2012, 08:22 PM   #3
1992 Lx hatch
how do i test that? i do have a multimeter but donto know aht setting to put on
Old February 6th, 2012, 10:18 PM   #4
fogged306's Avatar
89 GT
20 or 200 VDC usually, or just VDC if it's an autorange.
Old February 6th, 2012, 10:33 PM   #5
ryanw's Avatar
1991 Ford Mustang GT
What about checking the fuse links for the alternator and voltage regulator
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 7th, 2012, 07:54 AM   #6
1992 Lx hatch
where are these fueses located? any pictures ?
Old February 7th, 2012, 11:13 AM   #7
ryanw's Avatar
The fuse links are at the starter soleniod.
It should be the black wire with orange stripe.
What happens is the black wire with orange stripe leads over to the soleniod a long with a smaller yellow wire from the volt reg. Once the two wire are about 7 or 8 inches from the soleniod there conected to geather by afuse link, once they come out of the fuse link the wire changes color. I believe its the big fat green wire at the solenoid.
So follow the green wire down about 3 inches, you will see what looks like a spliced conection....thats the fuse link,
Under that fuse link you will see the black wire with orange stipe and a smaller wire running into the same fuse link, if you follow the smaller wire down another inch or two youll see another smaller fuse link. Check that one to, it for the vlot reg.
The smaller wire on my car was brown, bur turns into the yellow wire i was talking about, just before in goes under the battery tray.
To check these two wires you can either probe the wires on each side of the fuse link or disconect the battery and then remove the wires from the solenoid and remove the two plugs on the alternator and test from the plug ends.
The yellow wire is on the second plug on the underside of the alternator and the the black wire withorange stripe is the big plug on top.
I hope i didnt confuse you... sorry i cant explain things vary well, maybe some one else can clear this up for you.
It sound like a lot of work but its not, it just sounds that way because its coming from me...lol
Or guess another way to test would be to leave the conectors at the solenoid conected and leave the battery conected.....with the engine off see if you have 12 volts at the plug end of the yellow wire on the volt reg and 12 volts at the plug end of the black wire with orange stipe at the alternator
255 fuel pump,
3:27 gears
Old February 7th, 2012, 12:32 PM   #8
ryanw's Avatar
http://www.veryuseful.com/mustang/te...nks-ign-ac.gif
255 fuel pump,
3:27 gears
Old February 7th, 2012, 12:50 PM   #9
tyler97's Avatar
1991 gt cobra clone
tyler97 is on a distinguished road
If not that my did the same but my circuit board on the cluster was ripped so i re soldierd that and done deal works great.
1991 GT- Ripped torque boxes/no SFCs/306/24lb injectors/Twisted Wedge 170s/Full exhaust/Full bolt ons/X3Z computer
Buid thread http://www.moddedmustangs.com/forums...ld-thread.html
Old February 7th, 2012, 04:55 PM   #10
1992 Lx hatch
well i founf a frayed wire on the altonator pigtail went to napa bought new pigtail and soldered it in,
started car with new batt and it reads 12 volts while running i then dook it down the street and it read 12 volts after that.. think shes fixed!
Old February 7th, 2012, 05:33 PM   #11
ryanw's Avatar
I think you need some thing like 14 volts, im not sure.
How bad was it damaged.
Id still check the fuse links, cuz you might just be running off battery power
255 fuel pump,
3:27 gears
Old February 7th, 2012, 07:31 PM   #12
1992 Lx hatch
okay i will check tommoro, but the batt reads 12 volts now, not sure how bad it was damaged
Old February 7th, 2012, 07:40 PM   #13
1992 Lx hatch
how do i open up this fues link?
Old February 7th, 2012, 07:53 PM   #14
1987 mustang GT
10.92@122
yeah it should be 13.8volts
Old February 7th, 2012, 08:34 PM   #15
ryanw's Avatar
You dont open them up, you test them, if there bad you have to cut them out and solder new ones in
255 fuel pump,
3:27 gears
Old February 7th, 2012, 08:36 PM   #16
Troy5.0's Avatar
1988 mustang LX
Troy5.0 is on a distinguished road
fully charged should be 12.6 V not running if you need to know that.
Old February 7th, 2012, 08:40 PM   #17
ryanw's Avatar
Can some one please explain to him how to test fuse link for his alternator and volt reg
I think i over complicated the process
To the Op just remember there are two fuse links for your charging system one is for the alternator and the other is for the volt regultor
255 fuel pump,
3:27 gears
Old February 7th, 2012, 08:44 PM   #18
Troy5.0's Avatar
1988 mustang LX
use a test light if it lights up on both your good if it doesnt on one end well something to look into!
306 being built
Old February 7th, 2012, 08:45 PM   #19
fogged306's Avatar
89 GT
Both of these are within reason, but not the exact number you have to have or something is wrong. There's tolerances for batteries and regulators. Anything 12v and up at rest is a good battery. High 11's is still ok usually but could give you problems in an extreme cold climate, anything below that and the battery is weak. Charging system should be between 13.8v and 14.4v while running. A few tenths of a volt above and below is still acceptable. Get into the low 13's while running and I start looking for an issue, above 14.6 and the regulator is set too high. I've seen cars charge at 15.1v before and not have an issue, but I'd be worried if it was my car.
Old February 7th, 2012, 08:54 PM   #20
ryanw's Avatar
255 fuel pump,
3:27 gears
Threads Similar to: car running off batt
BATT light-electrical draw 5.4mustang gt 99-04 0 August 25th, 2010 05:13 PM
Batt voltage Pharoh 5.0 Mustangs 10 August 4th, 2010 01:47 AM
Volts/alternator/batt/? Mustangboi21 V6 Mustangs 8 March 27th, 2009 02:20 AM
Alt. & Batt. Prankster V6 Mustangs 19 October 9th, 2008 07:57 PM
Batt Terminals dgt_mustang V6 Mustangs 0 June 21st, 2008 01:05 PM
