5.0 Rough Idle
Old February 6th, 2012, 09:05 PM   #1
89-5.0Fox is on a distinguished road
5.0 Rough Idle
I have a bone stock 89 LX Hatch with the 5.0. So almost every single time I start it up it does the automatic idle up but then instantly drops to like 400-500 rpms and then goes back up and idles up and down untill Its driven a little bit or unless I hold it at like 1000 rpms for a bit then it seems to do alright. It seems like it just does it when I first start it up. Any ideas?
Old February 6th, 2012, 09:15 PM   #2
I need a 5 lug kit
Ninety3Coupe's Avatar
1993 Mustang LX 5.0
Ninety3Coupe is on a distinguished road
I could be wrong, but clean the TB? (Hint: using carb cleaner is not recommended by Ford due to a coating on the metal - disregard this tip at will - many do - myself included).
TPS sensor?
IDK, anyone else?
Half of Maximum Motorsports Catalog, Full Intake, Full Exhaust. Needs paint and $35,000 in mods. Car / Build Photos: http://photobucket.com/CoupePictures
Old February 6th, 2012, 10:24 PM   #3
So just take the Throttle Body completely off? Do they make like a throttle body cleaner?
Old February 6th, 2012, 11:03 PM   #4
I need a 5 lug kit
1993 Mustang LX 5.0
Pull the intake leading to the TB, and spray the inside of the TB down with (yes they make it) TB cleaner. Open the blade and get in there with a rag or the like and spray away. Removing it is the best way to clean the back of course, but start with the easy way. If you do leave it on the car, wedge a long (so as not to drop it in there) stick to wedge the TB blade open for 30 minutes or so to allow it to evaporate and then start her up.
At least that's how I do it...
Old February 6th, 2012, 11:22 PM   #5
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Also, pull off your idle air control valve (IAC) off the throttle body and clean it out as well. It is also possible that your IAC is shot too.
Old February 7th, 2012, 10:09 AM   #6
Alright I'll try it tonight and see what happens. Thanks a bunch!
Old February 7th, 2012, 11:03 AM   #7
I need a 5 lug kit
1993 Mustang LX 5.0
Good call Fast. Can't believe I forgot that. Lol
Sent from my Autoguide iPhone app
Threads Similar to: 5.0 Rough Idle
Rough run and idle ddaniels750 99-04 13 July 16th, 2011 03:26 PM
Rough Idle killagt46_t-top 99-04 5 April 20th, 2010 11:22 AM
Rough idle and take off? nevets172006 V6 Mustangs 4 April 8th, 2009 12:33 PM
rough idle Gsturbo88 V6 Mustangs 8 March 22nd, 2008 08:36 PM
Rough Idle MineralGreyGT 99-04 19 January 5th, 2008 09:51 PM
