I need a intake manifold for my 86
Old February 6th, 2012, 09:32 PM   #1
86ttops's Avatar
86,97 mustang gt t tops
n/a
86ttops will become famous soon enough
Send a message via Yahoo to 86ttops
I am looking for a intake manifold for my 86. I was looking at the bbk ssi or the trick flow. I also need a throttle body. So my question is right now it is going on a stock 86 mustang. Being you cant really do much with this motor because of the flat top pistons. I want to build a 351w 393 stroker someday. So what is going to be a better choice for a later upgrade? I know i will have to change the lower intake. What size throttle body will work now and latter will a 75 mm work on the stoke 86? Thanks for any help.
Old February 6th, 2012, 10:30 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
Forget about bbk intakes, theres a few issues with them on top of them being over priced, my vote would be either trick flow or edelbrock, as for the tb, im thinking 75mm should be good, but you might want to look into doing a mass air conversion.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 6th, 2012, 10:38 PM   #3
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Also, just because you have flat top pistons, doesn't mean you can't do anything with the motor in the future. If you are referring to boost, then get a set of heads with a large combustion chamber cc. If you are referring to camshaft lift, you can grind your own valve reliefs in the pistons as well. As Ryan said, the bbk is really not impressive, and you know that you need a different lower intake for a 351, right? Also, the motor you have now and the 393 stroker are worlds apart, so no intake will be great for both of them.
Old February 6th, 2012, 10:44 PM   #4
Mustang Fanatic
ALEXLOPEZ62188's Avatar
1989 Mustang LX
ALEXLOPEZ62188 is on a distinguished road
+1
I'd just put bolt ons and some gears.
considering its a speed density car, you should consider a MAF conversion before an intake manifold..... unless you already converted?
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old February 6th, 2012, 10:47 PM   #5
ryanw's Avatar
what ever intake you choose, buy it used.....you will save a lot of money
255 fuel pump,
3:27 gears
Old February 6th, 2012, 10:59 PM   #6
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
You could go cobra also, there pretty cheap used. You can go upper and lower.
Old February 6th, 2012, 10:59 PM   #7
I need a 5 lug kit
Ninety3Coupe's Avatar
1993 Mustang LX 5.0
Ninety3Coupe is on a distinguished road
I just installed my Edelbrock Performer (not Performer II) and I love it. Made a world of difference. Just my 2 cents.
Half of Maximum Motorsports Catalog, Full Intake, Full Exhaust. Needs paint and $35,000 in mods. Car / Build Photos: http://photobucket.com/CoupePictures
Old February 6th, 2012, 11:16 PM   #8
86ttops's Avatar
n/a
Sorry guys it is mass air i converted it couple years ago.
Old February 6th, 2012, 11:18 PM   #9
86ttops's Avatar
n/a
As for as the 86 block yes i am refering to cam options its not worth tearing down a 302 and notching pistions.If i am going to do it i might as well start with a 351
Old February 6th, 2012, 11:22 PM   #10
Mustang Fanatic
1989 Mustang LX
if you're keeping your stock heads, an eddy performer, or GT40 series intake will be a good upgrade..
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Old February 6th, 2012, 11:29 PM   #11
1991 Mustang LX 5.0
Then I wouldn't spend a dime more on this motor than. You have a 351 block to purchase, rotating assembly, fox swap pan, fox swap headers, Intake, TB, possible larger mass air, larger injectors, ect. ect. See where I'm going with this. You have to pick your battles. Might as well buy an intake for you motor that you have now, and just plan on selling it off later, or start on the 351 project now. Any set of heads that you purchase for your 'now' motor won't support your 'future' motor either. At least not very well.
Old February 7th, 2012, 07:09 AM   #12
86ttops's Avatar
n/a
I hear ya just didnt want too.lol I think i have a line on a 351w that has been converted to roller it is boared 40 or 60 over he was gonna check its ready for a rotating assemble. probable go with eldbrock performer heads. I was looking at there efi spider intake a friend runs them and opinions on it? he thinks i should just buy a chp 408 short block and be done with it.
Old February 7th, 2012, 11:38 AM   #13
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
I would personally run a Ford Strokers shortblock, but that's just me. The EFI Spider intake is a nice piece.
The edelbrock Performer heads on the other hand...Out of the box with correct springs, retainers and locks can produce mid 11 second time slips on a light 302 or a normal weight 351 car. I would reccommend a nice Twisted Wedge head. They can be upgraded later on to be ideal to work with your 351. Just some food for thought..
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Threads Similar to: I need a intake manifold for my 86
Swapping a 98 V6 intake manifold with for a 99 V6 manifold 98mustang V6 Mustangs 6 November 20th, 2010 11:20 PM
Non PI intake manifold vs Aluminium crossover Intake manifold cedp83 96-98 6 September 10th, 2010 03:45 PM
Non PI intake manifold vs Aluminium crossover Intake manifold cedp83 99-04 1 September 9th, 2010 02:04 AM
Oil under intake manifold?? lil666 99-04 4 May 17th, 2007 07:56 PM
Which Intake Manifold bobnice 5.0 Mustangs 10 October 2nd, 2006 09:59 AM
