how can i get into the 12s?
Old February 6th, 2012, 11:34 PM   #1
06SuperStang's Avatar
2006 Mustang GT
06SuperStang is on a distinguished road
Ok so i just recently bought a 88 lx coupe that came with the e303 cam, magnaflow exhaust and a mac cold air intake. The previous owner didnt know to much about the car cause all he was told from the guy he bought it from that ot had the cam and that the motor was rebuilt 1000 miles ago. I dont even know if it has gears in the rear!!! But it will spin all through 1st 2nd and 3rd! It still has the factory headers on it. What can i look for to see if this thing has aftermarket heads or anything in general? Im mew to the 5.0 thing and any info would be great....also what does it take to get in the mid 12s?
2006 Mustang GT (Auto),FRPP Hot Rod Cams,Hooker Longtubes w/ Off Road X-Pipe,Stock Mufflers,TCI 3000 Stall,Delete Plates,C&L Racer CAI,Tuned By The Guys From American Muscle,FRPP 3.73's,Coast Line Full Length DriveShaft
Old February 6th, 2012, 11:56 PM   #2
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Mid twelves...There are many options.
Stock heads, cam, intake with injectors (24#) MAF, h-pipe and 3:73s with a 100 or 125 shot. Mid to high twelves easy.
Used trick flow 170cc heads, Anderson N41 cam, Holley systemax intake 3:73s and a 26 inch tire you can run mid to high elevens if you can drive.
Gt40p heads, Anderson N41 cam, tmoss ported explorer intake, 4:10s slicks and a little weight reduction (take passenger seat out, jack tire and shit etc.) You should get ~12.4-13.1 depending on the driver.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old February 7th, 2012, 12:12 AM   #3
ryanw's Avatar
1991 Ford Mustang GT
Post some pics of the engine..
If the heads are aluminum, then there not stock.
If the ends of the heads have 3 bars then there gt40 heads, if theres 4 bars then you have gt40p heads.
As for gears... jack up the rear, mark the drive shaft, spin the tire one full turn, and count how many times the drive shaft spun. For example if the drive shaft spun a little over 3 turns then you have 3.08 if it spins 3 1/4 then you have 3.27 ect... ect...
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 7th, 2012, 05:08 AM   #4
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
100 shot and sticky tires. (just so happen to have my old nitrous kits for sale )
take good pictures of the engine bay, and heads, and we can tell you what you got.
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old February 7th, 2012, 06:45 AM   #5
2006 Mustang GT
Ok i will get some pics up by the end of the week....thanks for thr in put! Im going to try the gear thing when i get off work.
Old February 7th, 2012, 07:18 AM   #6
skeletonpsycho's Avatar
1987 mustang GT
10.92@122
skeletonpsycho is on a distinguished road
lx coupe +373+drag radial and power shifting thats all you need to get into the 12s
http://www.youtube.com/watch?v=gQ7g9ystpiU 347 all motor wawa pump gas driven everywhere
Old February 7th, 2012, 08:44 AM   #7
El Conquistador
whiteboycustom's Avatar
83 coupe
whiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nice
Send a message via AIM to whiteboycustom Send a message via Yahoo to whiteboycustom
i bought my car and the owner lost the information on the cam that they put in it......thats rather aggravating if you ask me because i would like to know what cam it is without tearing the motor down
http://www.donttearmedown.com/
Old February 9th, 2012, 09:32 PM   #8
1993notch's Avatar
1993 lx notch
1993notch is on a distinguished road
i just bought my car from a buddy i know what the engine is, i helped him build it, stock bottom end, e303 cam, gt40p's, holley sistemax upper and lower, 70mm tb and egr spacer, 24# injectors with matched mass air, still has aod.....what should this run tuned right?
Old February 9th, 2012, 09:47 PM   #9
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Low 13's if you're lucky. The stock AOD will kill it without a shift kit and torque converter. If you have that already, high 12's if you can drive and hook.
Old February 9th, 2012, 10:00 PM   #10
1993notch's Avatar
1993 lx notch
i have a c4 thats built but 1 i dont want to loose od because i like driving my car to work and around and 2 i have a 66 mustang that i am building a resto mod out of so i was thinking the c4 would be better in that, should i put the c4 in with 373 rears or will it sing at 60mph?
Old February 9th, 2012, 10:05 PM   #11
1991 Mustang LX 5.0
Your call, just letting you know where it would stand. And yes, it would be revving at 60 with no OD and 3.73's. Don't pass a gas station, lol.
Old February 9th, 2012, 10:07 PM   #12
1991 Mustang LX 5.0
You can always just drive around in D for a while (and on the highway) and see how you like it with the AOD
Old February 9th, 2012, 10:13 PM   #13
1993notch's Avatar
1993 lx notch
thanks for the info man.
Old February 9th, 2012, 11:34 PM   #14
302Army187's Avatar
'89 LX 'Vert
T5 swap
you can hit mid 12's with that combo with a T5, sticky tires, and a good driver
Old February 10th, 2012, 01:26 AM   #15
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
careful with the torque boxes and stock control arms
