GT40P swap
Old February 7th, 2012, 12:48 PM   #1
1990 Mustang LX
Never ran it
BigO'Deal is on a distinguished road
Exclamation
GT40P swap
ok i had some recent threads on cheap bolt ons but i decided to just give up trying to find cheap hp. so i decided to just do a cheap head swap. ok my idea was some gt40p heads fully rebuilt and valve work, (im still waiting on the quote on that). i was looking at a Compcams k kit that ive heard some good reviews about. that providing the new springs, some Scorpian 1.6 rockers, the cam in the k kit has a .512 lift, 230* so it all works there. MSD distributor gear, and the timing chain. Explorer intake ported and polished, 24# injectors, 70mm TB & EGR, 1 inch intake spacer, and a proM MAF all on the stock bottom end. Yes its over what i should spend but it will be well worth it for me. oh and 4.10 gears cant forget them.
GT40P heads rebuilt & valve work, port/polish
CompCams k kit (cam,springs & hardware, timing chain)
scorpian 1.6 rockers
24# injectors
exploer intake ported & polished w/ 1'' intake spacer
BBK 70mm TB & EGR
ProM 75mm MAF
good setup for an easy 300 horsepower?
Old February 7th, 2012, 12:57 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
After you get the quote for doing the gt40 heads post up what it will cost before you buy and do the work. Cuz used trick flow heads can be had for around 800, so if the cost of the gt40 stuff is any where near that number, then id skip it and pay a few more bucks to have a better head. Just my opinion though
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 7th, 2012, 02:17 PM   #3
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Honestly, if you're dead set on a pair of GT40ps, go with the Thumper heads http://www.hunterstyle.com/thumper/ He does great work on them for a reasonable price (considering they're ready to bolt on).
BUT, if you're not dead set on them, I would consider Trick Flow 170cc twisted wedge heads for your car. Used, they can be had for 700-900$. They also have more potential and you will have room to grow with them.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old February 7th, 2012, 04:39 PM   #4
Mustang Fanatic
ALEXLOPEZ62188's Avatar
1989 Mustang LX
ALEXLOPEZ62188 is on a distinguished road
It'll make 300 ish at the flywheel.
My gt40 combo with tfs1 cam made about 275whp.
Right around where it should be.
But I got bored of that shit too quick and ended up doing the stroker and aluminum heads.
Save up a little longer and just do the trickflow heads. You'll be much happier with the results.
89 Mustang LX:
347
AFR
Comp Cam
TFS Track Heat
359rwhp
395rwtq
Threads Similar to: GT40P swap
gt40p help clint sizemore 5.0 Mustangs 18 November 22nd, 2011 11:11 PM
GT40P swap dirty_d 5.0 Mustangs 31 October 29th, 2011 10:22 AM
GT40P head/cam swap issue steve86gt 5.0 Mustangs 1 August 2nd, 2010 06:10 PM
89 Lx Gt40p stangage 5.0 Mustangs 7 September 14th, 2009 01:55 AM
gt40p Q's JBIGBOOTSY 5.0 Mustangs 12 February 18th, 2008 01:37 AM
